Solve the equation in cartesian and polar form: x^3 + 4\sqrt{1+i} = 0
  • Thread starter Thread starter bjgawp
    Complex
The problem involves solving the equation x^3 + 4√(1+i) = 0 and expressing the solutions in both Cartesian and polar forms. The context is rooted in complex numbers and polynomial equations.
  • The original poster attempts to manipulate the equation by moving the constant term and squaring both sides, leading to a sixth-degree equation. They express concern about the number of roots and whether all need to be tested.
  • Some participants suggest expressing 4√(1+i) in polar coordinates as a potential simplification.
  • Others express confusion about the complexity of the polar form and question the implications of introducing additional roots when squaring the equation.
  • There is a discussion about the principal value of the square root and its significance in determining the correct roots.
Participants are grappling with the implications of squaring the equation and the resulting increase in the number of roots. There is also a focus on the principal value of the square root in the context of complex numbers.
bjgawp
Solve: x^3 + 4\sqrt{1+i} = 0
and express in both cartesian and polar form.
e^{i\theta} = \cos (\theta) + i \sin (\theta)
What I did was move the constant term to the right hand side and squared both sides to get: x^6 = 16 + 16 i
which implies: x = (16+16i)^{1/6} = \left[16\sqrt{2}\right]^{1/6} e^{\frac{(8k+1)\pi i}{6}}
Then I simply sub in k = 0, 1, .., 5 for all my roots. But the original equation is a polynomial of degree 3. There should be only 3 factors. Do I have to test them all to see if they work? Or is there an easier way...
Thanks.
You introduced these extra roots when you squared both sides. To avoid having to substitute them into the equation, try expressing 4 \sqrt{ 1 + i } in polar coordinates.
I don't really see how that helps as it looks fairly complicated.
(1+i)^{\frac{1}{2}} = 2^{\frac{1}{4}} e^{\frac{(8k+1)\pi i}{8}}
which gives us two forms:
z_0 = 2^{\frac{1}{4}} \left(\cos \tfrac{\pi}{8} + i\sin \tfrac{\pi}{8}\right)
z_1 = 2^{\frac{1}{4}} \left(\cos \tfrac{9\pi}{8} + i\sin \tfrac{9\pi}{8}\right)
then substituting each of these back, I get two 3rd degree equations which again would give me 6 roots?
That's like saying solving x^3+sqrt(1)=0 means solving x^3+1=0 and x^3-1=0. Sure you get 6 roots. The 'sqrt' notation in your notation indicates only one of them. You want the 'principal value' of the square root. It's the pi/8 one.
9K
