Solve the given problem involving integration
chwala
see attached
integration
Textbook exercise 4: a) Show that d/dx (ln x / x) = (1 - ln x)/x^2. b) Hence find the integral of (ln x / x^3) dx.
This really cracked me up! Unless there is something i am not seeing!
part (a) is straightforward, using quotient rule:
##\dfrac{dy}{dx} = \dfrac{x⋅\dfrac{1}{x}- \ln x}{x^2}=\dfrac{1-\ln x}{x^2}##
From here i was able to see that,
##\int \dfrac{\ln x}{x^2} dx= \int \dfrac{1}{x^2}- \dfrac{\ln x}{x}##
## = -\dfrac{1}{x} - \dfrac{ln x}{x}=-\left[\dfrac{1+\ln x}{x}\right]##
on the other hand, using integration by parts( without using part (a) and (b)), gives me
##\int \dfrac{\ln x}{x^3} dx =\dfrac{-\ln x}{2x^2} + \int \left[\dfrac{-1}{2x^2}⋅\dfrac{1}{x}\right] dx##
##= -\dfrac{\ln x}{2x^2}+ \int \dfrac{-1}{2x^3} dx##
##= -\dfrac{\ln x}{2x^2}-\dfrac{1}{4x^2} +c##
but this does not satisfy my curiosity, as i did not use part (a), was there a mistake on the textbook or am i simply missing out on something?
So we have as you said
Equation 1
##\frac{d}{dx}\left(\frac{ \ln x}{x} \right) = \frac{1- \ln x}{x^2} = \frac{1}{x^2} - \frac{\ln x}{x^2}##
Which implies
Equation 2
##\frac{\ln x}{x^2} = \frac{1}{x^2} - \frac{d}{dx}\left(\frac{ \ln x}{x} \right)## This becomes important later
Starting with the integral
##\int \frac{\ln x} {x^3} \, dx = \int \frac{1}{x} \left(\frac{\ln x} {x^2} \right)\, dx##
substitute Equation 2 into the above
##\int \frac{\ln x} {x^3} \, dx = \int \frac{1}{x} \left( \frac{1}{x^2} - \frac{d}{dx}\left(\frac{ \ln x}{x} \right)\right)\,dx##
##\int \frac{\ln x} {x^3} \, dx = \int \left(\frac{1}{x^3} - \frac{1}{x} \frac{d}{dx} \left( \frac{\ln x}{x}\right)\right)\, dx##
Well the first term on the right hand side of the equals sign is easy enough to integrate readily
##\int \frac{\ln x} {x^3} \, dx = - \frac{1}{2x^2} - \int \frac{1}{x} \frac{d}{dx} \left( \frac{\ln x}{x} \right)\,dx##
Now use integration by parts on the integral on the right hand side of the equals sign
## v = \frac{\ln x}{x} ##
## dv = \frac{d}{dx} \left(\frac{\ln x}{x} \right) dx##
##u = \frac{1}{x}##
##du = - \frac{1}{x^2} ##
Plugging this all in
## \int \frac{\ln x}{x^3} \,dx = -\frac{1}{2x^2} - \frac{\ln x}{x^2} - \int \frac{\ln x}{x^3} \,dx##
## 2 \int \frac{\ln x}{x^3} \,dx = -\frac{1}{2x^2} - \frac{\ln x}{x^2} ##
##\int \frac{\ln x}{x^3} \,dx = -\frac{1}{4x^2} - \frac{\ln x}{2x^2} + C##
I get the same thing as you
chwala said:
... but this does not satisfy my curiosity, as i did not use part (a), was there a mistake on the textbook or am i simply missing out on something?
Yes. Firstly, you made a sign error. Twice, so that your result remained correct. Secondly, as @PhDeezNutz demonstrated, you missed a trick by not using part (a) of the problem. You solved it by integration by parts
\int (u'v)=uv-\int (uv')
which is faster and more suitable in this case. However, using part (a) would have meant to use
\mathcal{I}:=\int \dfrac{\log(x)}{x^3}=-\int \left(\underbrace{\dfrac{1-\log(x)}{x^2}}_{u'}\cdot \underbrace{\dfrac{1}{x}}_{v}-\dfrac{1}{x^2}\right)
which results in an equation
\mathcal{I}=f(x) -\mathcal{I} \Longleftrightarrow \mathcal{I}=\dfrac{f(x)}{2}
The trick to using the additive symmetry: an integral that shows up on both sides of the equation with an opposite sign. You do not "solve" the integral, you express it with another function: ##f(x).## A similar trick exists for multiplicative symmetries.
From a)
[tex]\frac{d^2}{dx^2}\frac{\ln x }{x}=-\frac{3}{x^3}+\frac{2}{x^3}\ln x[/tex]
[tex]\frac{\ln x}{x^3} = \frac{1}{2}\frac{d^2}{dx^2}\frac{\ln x }{x}+\frac{3}{2x^3}[/tex]
[tex]\int dx\frac{\ln x}{x^3} = \frac{1}{2}\frac{d}{dx}\frac{\ln x }{x}+\int dx\frac{3}{2x^3}[/tex]
So the same result with you @chwala .
anuttarasammyak said:
From a)
I really liked how you used the second derivative. Even though that’s not what the problem asked for I can still definitely appreciate it.
Edit: nvm you only used the second derivative so you could integrate it and get the first derivative and use part a) which is clever. Either way pretty cool.
I think it is fair that i fix the sign error, i will proceed as follows,
$$\int \dfrac{\ln x}{x^3} dx =\dfrac{-\ln x}{2x^2} - \int \left[\dfrac{-1}{2x^2}⋅\dfrac{1}{x}\right] dx + c$$
$$ =\dfrac{-\ln x}{2x^2} + \int \left[\dfrac{1}{2x^3}\right] dx+c$$
$$=\dfrac{-\ln x}{2x^2} +\dfrac{1}{2} \int \left[\dfrac{1}{x^3}\right] dx+c$$
$$=\dfrac{-\ln x}{2x^2} +\dfrac{1}{2} ⋅ \left(\dfrac{-1}{2x^2}\right)+c$$
$$= -\dfrac{\ln x}{2x^2}-\dfrac{1}{4x^2} +c$$
