Solve the Mystery of the Alarm Signal: Duncan's Story
  • Context: Undergrad
  • Thread starter Thread starter duncan108
    Mystery Signal
The discussion revolves around an unusual alarm signal experienced by a user named Duncan, who reports hearing a continuous beep from various electronic devices in his home at midnight. Participants explore potential sources of the signal, including radio-controlled clocks, smoke alarms, and other electronic devices, while also considering the possibility of reverb complicating sound localization.
  • Duncan describes a mysterious alarm signal that occurs at midnight, suggesting it may be a synchronizing signal from a clock or another electronic source.
  • Some participants propose that the signal could be from a smoke detector with a low battery or a wristwatch with a default alarm set for 11:59.
  • Others argue that the sound may be difficult to locate due to reverb issues within the home.
  • One participant suggests that the sound could be a digital alarm clock or device that was reset during a power failure, while another warns against assuming the devices are emitting alarms without further investigation.
  • Several participants emphasize the need for thorough searching and localization techniques to identify the source of the sound.
  • Some participants express skepticism about the possibility of the sound coming from the light fixture or being a prank, while others acknowledge the challenges of tracking electronic sounds.
Participants do not reach a consensus on the source of the alarm signal. Multiple competing views remain, with some suggesting electronic devices as the cause and others proposing alternative explanations.
Participants note the difficulty in locating high-frequency sounds and the potential for misinterpretation of the source due to acoustic properties in the environment.
This discussion may be of interest to individuals experiencing similar unexplained electronic sounds, those interested in sound localization challenges, or anyone curious about the behavior of electronic devices in residential settings.
  • #31
One thing you could try to see if it’s battery powered or coming from the mains is to kill your main incoming circuit breaker right when it starts or possibly a bit earlier. If it doesn’t go off it could be something plugged in somewhere.
  • #33
Wow that’s a great video. He should’ve stretched it out a bit and uncovered Al Capones secret vault.
  • #34
russ_watters said:
That's great, but uses a lot of equipment.
I wonder if one could use some simple listening cone and point it in different directions, to estimate the source direction based on the volume changes.
  • #35
I think the video would be too long if he used one mic at a time with a cone. :-)
Also, this guy was clearly rather impatient to find the source of the beep.
  • #36
The guy in the video seems to be an audio engineer who has lots of mics laying around. I was looking for a practical solution that the OP could apply.
  • #37
He said in the video he went to the store to get these mikes.
You could probably do the same thing with two mikes and narrow things down in a binary search sort of scheme.
  • #38
I tried and you can get to the right room (or maybe better) with a cell phone and a sound level app...if it is in a room. If it is in an above/below crawl space it may be more difficult to localize.
It's probably also possible to rig up a shotgun mic or mess with the microphone channels to make it directional.
I was actually hoping he was going to go a little more advanced than just "which is louder" and do a passive sonar scheme to localize it.
  • · Replies 19 ·
