Solving ∞^0 Indetermination: L'Hospital's Rule Help Needed
  • Thread starter Thread starter alejandro7
The problem involves evaluating the limit as x approaches infinity of the expression (1 + 2^x)^(1/x), which presents an indeterminate form of ∞^0. Participants are discussing the application of L'Hospital's Rule in this context.
  • The original poster attempts to apply L'Hospital's Rule but is uncertain about the steps. Some participants suggest transforming the expression using logarithms to facilitate the limit evaluation. Others question the form of the limit after applying logarithmic properties and discuss the conditions under which L'Hospital's Rule can be applied.
The discussion is ongoing, with participants providing guidance on how to manipulate the expression and apply L'Hospital's Rule. There is a focus on ensuring the correct form is used for the limit evaluation, and some participants emphasize the importance of exponentiating the result to obtain the final answer.
Participants are navigating the complexities of limits involving exponential and logarithmic functions, and there is an emphasis on understanding the implications of the indeterminate form. The discussion reflects a collaborative effort to clarify the steps involved without reaching a definitive conclusion.
alejandro7
Hi, I'm having troubles wiith this problem:
limit when x->∞ (1+2^x)^(1/x)
I don't know how to proceed (I know I have to use l'Hospital's rule). It's a ∞^0 indetermination.
Thanks!
Try letting
[itex]y=ln((1+2^{x})^{\frac{1}{x}})[/itex]
Then what can you do??
1/x goes down.
now what form is it in? Can you use l'hospital's rule now?
Don't forget, that now
[itex]e^{y}=(1+2^{x})^{\frac{1}{x}}[/itex]
So when you find y, the limit of
you have to take [itex]e^{y}[/itex] to get the answer to the limit you're looking for.
Ok I have:
e^lim when x-> of ((ln(1-2^x)/x))
L'Hôpital now?
Well you should have
lim x-->∞ [itex]\frac{ln(1+2^{x})}{x}[/itex]
Then use l'hospital's rule.
You will find the limit of this. To get the answer you want you have to exponentiate it (since you took the natural log in order to find it).
  • · Replies 16 ·
