Solving a 2nd Order Differential Equation with Exponential Terms
12 replies · 3K views · last reply
squaremeplz
[tex]\frac { d^2 \theta }{d x'^2 } = -y *exp(\theta)[/tex] eq. 1
mayb be integrated to yield
[tex]exp(\theta) = \frac {a}{cosh^2(b \frac{+}{-} \sqrt \frac{a*y}{2} * x')}[/tex]
[tex]\theta = f(y,x')[/tex]
the exponent is throwing me off, but i probably have to use the following properties
[tex]\frac { d^2 \theta }{d x'^2 } + \sqrt{y}*exp(/theta) = 0[/tex]
[tex]g = [1/2 (e^k^x + e^-^k^x)]^2 = cosh^2(kx)[/tex]
the problem is the exp(theta), do I have to replace the variable with something like
g = ln(theta)
then find
[tex]\frac { d^2 g }{d x'^2 }[/tex]
to get
[tex]\frac { d^2 g }{d x'^2 } + \sqrt{y}*g = 0[/tex]
then apply
m^2 + k^2 = 0?
thanks
I'm confused. In the other thread you started, you have
[tex]\frac { \partial^2 \theta }{\partial x'^2 } = -y *exp(\theta)[/tex]
and in this one you have it as a 2nd-order ODE.
Since theta is a function of y and x', you really need partial derivatives, not ordinary derivatives. If theta were a function of a single variable, say x', then you could talk about d(theta)/dx' and d^2(theta)/dx'^2.
Having said that, how do you go from equation 1 to this equation? IOW, how did y in the first equation become sqrt(y) in this equation?
[tex]\frac { d^2 \theta }{d x'^2 } + \sqrt{y}*exp(\theta) = 0[/tex]
sorry, at first it was a partial derivative but then I realized that theta is only dependent on the spatial variable x', like you said. Since this is a steady state problem (conditions for the problem approaching a steady state are given by the rate of reaction, it reduces to a ODE
Anyway,
I found more info on how to solve the equation
[tex]x' = \int \frac{d \theta}{\sqrt{-2*\int -y*exp(\theta) d \theta}}[/tex]
then i get
[tex]x' = \int \frac {d\theta}{\sqrt{2*y*exp(\theta) + 2*y*c}}[/tex]and now I am trying to figure out the above integral.
Factor 2y out of the terms in the radical and bring them out of the radical and out of the integral so that you have exp(theta) + c in the radical. I would then see if a substitution would work.
ok so following ur suggestion i did
[tex]x' = \frac {1}{\sqrt{2y}} * \int \frac {d\theta}{\sqrt{\int exp(\theta)d\theta}}[/tex]
[tex]x' = \frac {1}{\sqrt{2y}} * \int \frac {d\theta}{\sqrt{ exp(\theta)+c}}[/tex]
then i use the identity for int 1/sqrt(theta^2 + a^2) that is
[tex]x' = \frac {1}{\sqrt{2y}} * ln | exp(\theta/2) + \sqrt{exp(\theta) + c} | + a[/tex]
but when i try to solve for theta, i don't know how to reduce the exp to fit the form of the solution the book gives for exp(theta)
Not sure if this will help, but the integral formula you used can be expressed another way.
[tex]\int \frac{dx}{\sqrt{x^2 + a^2}}~=~sinh^{-1}(x/a) + C[/tex]
One thing I've been bothered by is treating y as if it were a constant in the integration with respect to theta. You have theta = f(y, x'), and in the other thread you said that y = x/x'.
hey mike, thanks so much for your hlep. yes that identity definitely helps.
please try to ignore the other post
y here is known as the frank-kamenetskii parameter
[tex]y = \frac {E}{RT^2_a} \frac {Q}{h} *r^2*z*exp(-E/RT_a)[/tex]
now, the r^2 in the y comes from x' = x/r
this is the substitution to drop the units of x, where r can be the half width or radius of a cylinder.
specifically, by the chain rule
[tex]\Delta x' = r^2 \Delta[/tex]
Quoting the book, In the simplest problems, the boundary condition is \theta = 0 at the surface, and the critical condition reduces to [tex]y = const = y_c_r_i_t[/tex] since neither in the equation nor in the boundary condions are there any parameters other than y.
So i think its ok to factor out y, no?
That's Mark...
You have [tex]\Delta x' = r^2 \Delta[/tex]
Don't you mean this?
[tex]\Delta x' = \Delta r^2[/tex]
Based on what you said about y, sounds like you can move it out of the integral.
sorry, mark :)
I still don't get the same answer as in the book
I did
[tex]x' = \frac {1}{\sqrt{2y}} * sech^-^1 (\frac {exp(\frac {\theta}{2})}{\sqrt{c}}) + a[/tex]
when I solve for [tex]exp(\theta)[/tex] i get
[tex]exp(\theta) = c* sech^2(\sqrt{2y}*x' + a)[/tex]
then
[tex]exp(\theta) = \frac {2c}{cosh^2 (\sqrt {2y}*x' + a)}[/tex]
the only problem now are the constants, the book has
[tex]exp(\theta) = \frac {a}{cosh^2 ( \sqrt {\frac {ay}{2}}*x' \frac {+}{-} b)}[/tex]
im confused why they have +/- and why it is sqrt(ay)/2
im confused why they have +/- and why it is sqrt(ay/2)
alrighty
well, thanks again for getting me this close. great help :)
