Solving a⁻¹ - b⁻¹ = b - a /(ab)
  • Thread starter Thread starter Nathi ORea
The discussion revolves around the equation a⁻¹ - b⁻¹ = b - a /(ab), focusing on the interpretation and manipulation of expressions involving negative exponents and fractions.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants explore the meaning of negative exponents and how to express them as fractions. There is a discussion about whether the equation is meant to be solved or shown as a true statement. Some participants question the clarity of the original equation and suggest the need for parentheses to avoid ambiguity.
Participants are actively engaging with the problem, offering clarifications on negative exponents and common denominators. Some guidance has been provided on how to manipulate the fractions, but there is still uncertainty regarding the original equation's intent and structure.
There is a mention of constraints regarding the values of a and b, specifically that they should not be zero. The discussion also highlights the importance of understanding common denominators in the context of the problem.
Nathi ORea
Thread moved from the technical forums to the schoolwork forums
TL;DR Summary: solving
a⁻¹ - b⁻¹ =
b - a /(ab)
I know that;
a⁻¹ - b⁻¹ =
b - a /(ab)
I am so lost as to how this answer is found. Can someone please give me a hint on any rules that allows you to solve this. A link perhaps
Thanks heaps.
Note that ##a^{-1}=\frac{1}{a}## and ##b^{-1}=\frac{1}{b}.## If that's not clear, it would be a good idea to review how negative exponents work. We can put these fractions over the common denominator of ##ab## so:
$$\frac{1}{a}-\frac{1}{b}=\frac{b}{ab}-\frac{a}{ab}=\frac{b-a}{ab}$$
$$a^{-1}=a^{0-1}=\frac{a^0}{a^1}=\frac{1}{a}$$
When it comes to functions that are not constants, the rule changes:
Remark at "Calculus - A Complete Course 7th ed - Robert A. Adams and Christopher Essex":
"Do not confuse the ##-1## in ##f^{-1}## with an exponent. The inverse ##f^{-1}## is not the reciprocal ##1/f##. If we want to denote the reciprocal ##1/f(x)## with an exponent we can write it as ##\left(f(x)\right)^{-1}##
Nathi ORea said:
solving a⁻¹ - b⁻¹ = b - a /(ab)
There is no solving (in the sense of finding values, such that the equation is satisfied).
Do you mean "showing " ?
And: did you really mean a⁻¹ - b⁻¹ = b - a /(ab) ? Or did you mean: a⁻¹ - b⁻¹ = (b - a) / (ab) ?
a⁻¹ - b⁻¹ =
b - a /(ab)
As already noted, this problem is not about solving an equation, but rather, proving that it is a true statement, at least for ##a \ne 0## and ##b \ne 0##.
It can only be the latter.
@Nathi ORea, as written the right side of the equation is b - a /(ab), which means ##b - \frac a {ab}##. Although you used parentheses on the right side, you didn't use enough of them. If you want to write ##\frac{b - a}{ab}## without using LaTeX, write this as (b - a)/(ab), as @BvU did.
Thanks heaps for the reply.
I did know the negative exponents. I would have got as far as 1/a- 1/b. I should have included that. I just wanted to get this question in quickly before work, so when I got home I had something to work off.. lol
I don't really get what you did after that sorry..
1/a- 1/b to a/(ab) - b/(ab).
I am not sure how you did that? Can you please explain.
I get the next step from:
a/(ab) - b/(ab) to (a-b)/(ab)
I'm fine with that at least.
I appreciate your help.
I appreciate your answer.
I am a pretty untalented 43 year old who is slowly (very slowly) making his way though a year 11 NSW textbook.. That sentence goes completely over my head.. lol.
I do understand that logical pathway though (if that is the correct usage at all), just the leap from:
I didn't quite get. How are they the same?
Sorry. I am not good with the lingo. I'll remember that.
Thanks.
Yup. I stuffed up there ;)
If you have a fraction, you can always multiply the numerator and denominator of the fraction by the same (nonzero) number, without changing the value of the fraction, for example, ##\frac{3}{4}=\frac{3\times 5}{4\times 5}=\frac{15}{20}.## This should make sense- if you have ##5## times as much money to distribute equally among ##5## times as many recipients, for example, then the amount of money each person receives is unchanged.
In our case, we can multiply the numerator and denominator of ##\frac{1}{a}## by ##b## to see that it is equal to ##\frac{b}{ab}## and similarly ##\frac{1}{b}## is equal to ##\frac{a}{ab}## (you wrote this backwards in the message I quoted).
This is only hindering the OP, who's not at this level yet.
  • Sad
This problem is an example of using what is called a common denominator. You should have heard about them. The post above by @Infrared shows how useful this is when you have specific fractions, like
$$\dfrac 1 2 - \dfrac 1 3 = \dfrac 3 6 - \dfrac 2 6 = \dfrac 1 6$$Or, when you have algebra to do:
$$\dfrac 1 a - \dfrac 1 b = \dfrac {b}{ab} - \dfrac {a}{ab} = \dfrac{b-a}{ab}$$In the first case, we used a common denominator of ##6 = 2 \times 3##. In the second case, the common denominator was ##ab##.
Would you agree that we can multiply by (ab)/(ab) {when a and b are not zero} without changing the value?
So multiply (1/a) by (ab)/(ab) can be arranged as [(ab) / a ] * [ 1 / (ab) ] = b * [ 1 / (ab) ] = b / (ab).
Do the same for the (1/b) term then combine.
Thanks for that. I went back and learnt how to do it. I appreciate you gave it a name, because it makes it easier to search it up.
  • · Replies 32 ·
  • · Replies 18 ·
  • · Replies 20 ·
