Solving a⁻¹ - b⁻¹ = b - a /(ab)
  • Thread starter Thread starter Nathi ORea
13 replies · 2K views
Nathi ORea
Thread moved from the technical forums to the schoolwork forums
TL;DR Summary: solving
a⁻¹ - b⁻¹ =
b - a /(ab)
I know that;
a⁻¹ - b⁻¹ =
b - a /(ab)
I am so lost as to how this answer is found. Can someone please give me a hint on any rules that allows you to solve this. A link perhaps
Thanks heaps.
Note that ##a^{-1}=\frac{1}{a}## and ##b^{-1}=\frac{1}{b}.## If that's not clear, it would be a good idea to review how negative exponents work. We can put these fractions over the common denominator of ##ab## so:
$$\frac{1}{a}-\frac{1}{b}=\frac{b}{ab}-\frac{a}{ab}=\frac{b-a}{ab}$$
$$a^{-1}=a^{0-1}=\frac{a^0}{a^1}=\frac{1}{a}$$
When it comes to functions that are not constants, the rule changes:
Remark at "Calculus - A Complete Course 7th ed - Robert A. Adams and Christopher Essex":
"Do not confuse the ##-1## in ##f^{-1}## with an exponent. The inverse ##f^{-1}## is not the reciprocal ##1/f##. If we want to denote the reciprocal ##1/f(x)## with an exponent we can write it as ##\left(f(x)\right)^{-1}##
Nathi ORea said:
solving a⁻¹ - b⁻¹ = b - a /(ab)
There is no solving (in the sense of finding values, such that the equation is satisfied).
Do you mean "showing " ?
And: did you really mean a⁻¹ - b⁻¹ = b - a /(ab) ? Or did you mean: a⁻¹ - b⁻¹ = (b - a) / (ab) ?
Reply
a⁻¹ - b⁻¹ =
b - a /(ab)
As already noted, this problem is not about solving an equation, but rather, proving that it is a true statement, at least for ##a \ne 0## and ##b \ne 0##.
It can only be the latter.
@Nathi ORea, as written the right side of the equation is b - a /(ab), which means ##b - \frac a {ab}##. Although you used parentheses on the right side, you didn't use enough of them. If you want to write ##\frac{b - a}{ab}## without using LaTeX, write this as (b - a)/(ab), as @BvU did.
Reply
Thanks heaps for the reply.
I did know the negative exponents. I would have got as far as 1/a- 1/b. I should have included that. I just wanted to get this question in quickly before work, so when I got home I had something to work off.. lol
I don't really get what you did after that sorry..
1/a- 1/b to a/(ab) - b/(ab).
I am not sure how you did that? Can you please explain.
I get the next step from:
a/(ab) - b/(ab) to (a-b)/(ab)
I'm fine with that at least.
I appreciate your help.
I appreciate your answer.
I am a pretty untalented 43 year old who is slowly (very slowly) making his way though a year 11 NSW textbook.. That sentence goes completely over my head.. lol.
I do understand that logical pathway though (if that is the correct usage at all), just the leap from:
I didn't quite get. How are they the same?
Sorry. I am not good with the lingo. I'll remember that.
Thanks.
Yup. I stuffed up there ;)
If you have a fraction, you can always multiply the numerator and denominator of the fraction by the same (nonzero) number, without changing the value of the fraction, for example, ##\frac{3}{4}=\frac{3\times 5}{4\times 5}=\frac{15}{20}.## This should make sense- if you have ##5## times as much money to distribute equally among ##5## times as many recipients, for example, then the amount of money each person receives is unchanged.
In our case, we can multiply the numerator and denominator of ##\frac{1}{a}## by ##b## to see that it is equal to ##\frac{b}{ab}## and similarly ##\frac{1}{b}## is equal to ##\frac{a}{ab}## (you wrote this backwards in the message I quoted).
Reply
This is only hindering the OP, who's not at this level yet.
Reply
  • Sad
This problem is an example of using what is called a common denominator. You should have heard about them. The post above by @Infrared shows how useful this is when you have specific fractions, like
$$\dfrac 1 2 - \dfrac 1 3 = \dfrac 3 6 - \dfrac 2 6 = \dfrac 1 6$$Or, when you have algebra to do:
$$\dfrac 1 a - \dfrac 1 b = \dfrac {b}{ab} - \dfrac {a}{ab} = \dfrac{b-a}{ab}$$In the first case, we used a common denominator of ##6 = 2 \times 3##. In the second case, the common denominator was ##ab##.
Reply
Would you agree that we can multiply by (ab)/(ab) {when a and b are not zero} without changing the value?
So multiply (1/a) by (ab)/(ab) can be arranged as [(ab) / a ] * [ 1 / (ab) ] = b * [ 1 / (ab) ] = b / (ab).
Do the same for the (1/b) term then combine.
Reply
Thanks for that. I went back and learnt how to do it. I appreciate you gave it a name, because it makes it easier to search it up.
Reply
