Solving a differential Eq. by separation of variables
The differential equation y' = y^2 - y can be solved using separation of variables. By applying partial fraction decomposition, the integral leads to the expression ln((y-1)/y) = t + c. The solution can be simplified to y = 1/(1 - ce^t), where c is a constant. However, the solution does not account for the case where y(t) = 0, which is also a valid solution. Therefore, the complete set of solutions includes y = 1/(1 - ce^t) and y = 0.
Duderonimous
Find all solutions. Solve explicitly for y.
y^{'}=y^{2}-y
Case where y'=0
0=y(y-1) y=0,1 when y(t)=0
Case where y'\neq0
y'=y^{2}-y
\frac{1}{y^{2}-y}y'=1
\int\frac{1}{y^{2}-y}y'dt=∫1dt
\int\frac{1}{y^{2}-y}dy=t+c
Cant figure our where to go from here.
##\displaystyle\frac{1}{y^2 - y} = \frac{1}{y(y-1)}##
Use partial fraction decomposition to split the above into the form ##\displaystyle\frac{A}{y} + \frac{B}{y - 1}##. Then, integrating will be a breeze.
1=A(y-1)+By
1=Ay-A+By
A=-1
B=1
\int\frac{1}{y(y-1)}=\int\frac{-1}{y}+\frac{1}{y-1}
\int\frac{-1}{y}+\frac{1}{y-1}=t+c
-ln|y|+ln|y-1|=t+c
ln(\frac{y-1}{y})=t+c
ln(1-\frac{1}{y})=t+c
1-\frac{1}{y}=e^{t+c}
y=\frac{1}{1-e^{t+c}}
I don't think this is right, wolfram alpha says it is y=\frac{1}{1+e^{t+c}}
How does the plus sign pop up into the denominator?
You've assumed |y-1| = y-1. Is this consistent with the range of y you get when you push on to the solution? The absolute value matters, you can't just drop it and move on.
I believe it's due to the fact that the ##|y - 1|## can also be written as ##|1 - y|##, perhaps that is what Wolfram used. In any case, note that ##e^{t+c} = e^ce^t = ce^t## because ##e^c## is still a constant. So ##\displaystyle y = \frac{1}{1 - ce^t}## would be the best way to write the answer, since if ##c## is indeed negative, it would look like what Wolfram has.
If 0 < y < 1 , then \displaystyle 1-\frac{1}{y}&lt;0\,,\ so that \displaystyle \left|1-\frac{1}{y}\right|=-\left(1-\frac{1}{y}\right)\ .
That will give \displaystyle 1-\frac{1}{y}=-e^{t+C}\ .
You were asked to find all solutions. Your formula, once you have solved for y, will give all except one solution. What is the solution you are missing?
It won't give the y solution where y(t)=0 so all solutions for y are
y=\frac{1}{1 - ce^t},0
where c is any real number
Right?
Yes, that is correct.
