Solving a first-order differential equation from chemical kinetics
sparkle123
d[A]/dt=-(k+k`)[A]+k`[A]0
The solution of this first-order differential equation is:
[A]= (k`+ke^(k`+k)t)*[A]0/(k`+k)
Could you please explain how you get from the first equation to the second? THANKS!
btw: if this helps, this is part of the solution for a chemical kinetics (rates/equilibrium) problem
so A is the reactant, t is the time, and k and k` are the rate constants for the reaction A==B
If I am reading it correctly, your DE is
[tex]\frac{dA}{dt}=-(k+k`)A+k'A_0[/tex]
Which can be rewritten as
[tex]\frac{dA}{dt}+(k+k`)A=k'A_0[/tex]
Since this is in the form
[tex]\frac{dA}{dt}+P(t)A= Q(t)[/tex]
an integrating factor 'u' is given by
[tex]u=e^{\int P(t) dt}[/tex]
see http://en.wikipedia.org/wiki/Integrating_factor" for more info.
