Solving a logarithmic equation
  • Thread starter Thread starter xxwinexx
    Logarithmic
3 replies · 3K views
xxwinexx
(e^x)^2-5(e^x)=0
I've reviewed my logarithmic rules, but I cannot get to the right solution. I should be trying to get one e^x on each side so that I can take the ln of both sides and end up with a simple algebraic process to solve.
This is as far as I get without running into my problem:
(e^x)^2=5(e^x)
I guess here I could take the ln of both sides, but I guess I'm confused about what happens to the x^2, and to the 5.
Edit:
Ahh, Thanks for the reminder. Don't want to bump this any more.
Took ln of both sides, ended with:
2x=ln5+x
x=ln5
Is that the correct way to that solution?
Remember your exponent and logarithm rules (they're pretty similar): If a, b, and c are real numbers, then:
(ab)c = abc
and
ln(a) + ln(b) = ln(ab).
The latter is derived from the fact that eaeb = ea+b.
Indeed. You can check it by replacing x with ln(5) in the original equation. Since both sides are positive (the natural logarithm has only a positive domain), it is also the only real solution.
xxwinexx said:
(e^x)^2-5(e^x)=0
If you let y= ex, then your equation is y2- 5y= y(y- 5)= 0. Can you solve that?
(e^x)^2=5(e^x)
?? There is NO x^2. There is (e^x)^2.
Edit:
2x=ln5+x
x=ln5
