Solving a Second-Order Linear Differential Equation with Constant Coefficients
  • Thread starter Jbreezy
24 replies · 7K views · last reply
Jbreezy
Solve 12y'' -5y' -2y = 0
So I'm not really sure how to do this at all. I feel like he took this out of left field.
What is I rewrote it as 12y'' -5y' = 2y Then what if I integrated it.
I may get 12y' - 5y = y + C ? Then I could use an integrating factor because it is of that form? And just go from there? Is this OK. Or am I making stuff up?
Making stuff up. If you integrate 2ydy you get y, but you need to integrate 2y with respect to whatever the independent variable is. And it's not y. This is a different type of problem. It's a linear differential equation with constant coefficients. http://en.wikipedia.org/wiki/Linear_differential_equation
It sent me to nothing ... I got this Wikipedia does not have an article with this exact name
How to I handle this problem
I regoogled it and found the article idk why ur link didn't work
Because my copy and paste function often double copies and I missed that one. So it's badly formatted. I fixed it.
Sorry I'm still unsure of how to go about this problem. I'm looking over the example. But I don't understand really.
You probably just haven't looked at it enough. Assuming your dependent variable is x, assume a solution has the form y=e^(kx). Put that into the ode and try to figure out what the possibilities for k are. That's the jist of it. It's pretty simple really.
OK. I did it a little different looking at an example. I just
let y'' = r^2 and y' = r in my equation
12r^2 -5r - 2 = 0 and I factored it. I get r = (1/4) and r = (2/3) so then I looked at how this example reported there answer and they had.
Y(x) = C1 e^(1/4)z + C2e^(2/3)z
I'm not sure why they choose z or even why it get;s this form for the solution
You are trying to go too fast without understanding what you are doing. For one thing, I get r=(-1/4) (not +1/4) or r=(2/3). If your independent variable is x then e^(-x/4) and e^(2x/3) are both solutions. Check that first.
Well I'm going fast because it is late here an I have examination in another course in the morning so forgive me for my lack of understanding. So, you don't even get 2/3 as an answer?
Yes, I do. Didn't I say that I did? Why are asking? This is what I mean by 'too fast'.
Kind of I got confused by your language. So I should pop this those in my original differential equation? Yes I think so.
Alright I got 0 for both in the original. So what is with how they write the answer? In that form?
Good idea. That should make it doubly clearer why the roots of 12r^2 -5r - 2 = 0 give you the exponents for solutions to your ODE.
OK so what about this one because I can't factor this like the other one...
y'' -4y' +5y = 0
They should have written y(x)=C1*e^(-x/4)+C2*exp(2x/3), with C1 and C2 being constants. I don't know where the z came from. You can see that also solves your diffy q, right? The rest of the story, which I'm not going to go into here, is that a 2nd order ode like that has exactly two independent linear solutions. So that is not only A solution, ALL of the solutions must have that form. I'm sure all of this stuff is in your textbook or course somewhere.
y'' -4y' +5y = 0
You can still find complex roots which will give you complex exponentials. Which will turn out to be products of sines, cosines and ordinary real exponentials via Euler's formula. This stuff has got to be in your course someplace! I'm not going to try to explain the whole thing from scratch.
What is exp(2x/3)?
e^(2x/3). I sometimes write e^x as exp(x). I slipped.
No I understand your not wanting to explain it from scratch. Believe me I wouldn't want to either. Also this is not in this section of the book. My teacher gives a course pack along with this. I get about 0 theory in my course he just gives examples. But this second one is not anywhere.
y'' -4y' +5y = 0
You don't factor a differential equation in any case. You solve the corresponding "characteristic equation" which is [itex]r^2- 4r+ 5= 0[/itex]. That is a quadratic equation that cannot be factored (with integer coefficients) but can be solved by "completing the square" or the "quadratic formula".
The solutions will be complex numbers. Do you know what to do when the characteristic solutions are complex numbers?
No. It was our assignment and then he said don't worry about ha! I don't know though.
