Solving a Separable 2nd Order Differential Equation
4 replies · 3K views
Atomos
In an investigation of a physics problem, I ran into the following equation:
d^2(y)/(dt)^2 = k * y * (y^2 + c)^-1.5
I know how to solve separable first order differential equations but this one seems to be beyond me. Assistance?
hmm I don't think that one can be solved analytically, can you settle for a numeric answer?
Well, one thing you can do is multiply by y prime
[tex]y^{\prime} y^{\prime \prime} = \frac{k y y^{\prime}}{(y^2 + c)^\frac{3}{2}}[/tex]
and then integrate to get
[tex]\frac{1}{2} y^{\prime 2} = - \frac{k}{\sqrt{y^2 + c}} + A[/tex]
where A is a constant of integration.
You can then square root the y prime square, pull over all the y stuff on one side (and integrate again) to get x as some horrendous integral in y.
i.e.,
[tex]x = \int{\frac{dy}{\sqrt{2(A- \frac{k}{\sqrt{y^2 + c}})}}}[/tex]
or rather
[tex]x = \frac{1}{\sqrt{2}} \int{\sqrt{\frac{\sqrt{y^2 +c}}{A \sqrt{y^2 +c} - k }} dy}[/tex]
Other than that, I dunno.
That looks intractable. I expected there to be a "clean" or closed (or whatever you call it) solution. This equation arose from me trying to plot the position of a point mass in a field generated by another point mass. The y is the vertical position (the reference point mass is at the origin and is stationary).
With the use of a clever substitution, it may yet be soluble. You never know.
