Solving a Trigonometric Integral
The discussion revolves around solving the trigonometric integral ∫(sin(x)-sin²(x)/√(sin²(x)+c)) dx, where c is a constant. Participants explore various approaches to integrate this expression, including substitution and integration by parts.
  • Homework-related
  • One participant requests help with the integral, presenting the original expression.
  • Another participant reformulates the integral but questions if it is the correct expression to integrate.
  • Several participants suggest checking an attached JPG file for clarification on the integral's expression.
  • One participant proposes using the substitution u=sin(x) to simplify the integral to ∫(u-u²/√(u²+c)) du.
  • Another participant notes that the substitution leads to a derivative that does not match the original integral's form.
  • Concerns are raised about integration by parts resulting in a more complicated expression, prompting requests for alternative methods.
  • A participant mentions that applying a specific method with a substitution for c may simplify the integral.
Participants express varying opinions on the best approach to solve the integral, with no consensus on a single method or solution. Some suggest substitution while others highlight complications with integration by parts.
Some participants indicate that the integral's primitive may be complex, and there are unresolved aspects regarding the correct expression and the implications of different methods proposed.
yanic
Can anyone please help to solve this following integral?
∫(sin(x)-sin^2 (x)/√(sin^2 (x)+c)) dx
c is a constant
Re: integral
c is a constant
Integral belongs to calculus...
is this what you want to integrate?
$$\int\frac{\sin(x)-\sin^2(x)}{\sqrt{\sin^2(x)}}+c$$
Regards,
$$|\pi\rangle$$
Re: integral
Please check the JPG file for the correct expression of
the function.
Best...
Re: integral
pape said:
https://www.physicsforums.com/attachments/1302
the function.
Best...
"And what I have found so far is" What is "what you have found"? How did you get this line? What does it mean?
How does the derivative relate to the given problem?
Please be more specific.
-Dan
Re: integral
-Dan
Please check the attached file.
I hope that I have been more specific this time.
Regards
Re: integral
You can start by substituting $u=\sin(x)$ to obtain
$$\int u-\frac{u^2}{\sqrt{u^2+c}}\, du$$
From there you can try integration by parts.
Re: integral
If $$u= \sin(x)$$ Then $$du=\cos(x)\,dx$$ which is not same as that function he wants to integrate?
Regards,
$$|\pi\rangle$$
Re: integral
Hello,
Integration by part leads to a more complicated expression at the end for the finding of the primitive.
Do you have any other suggestion please?
Regards
Re: integral
pape said:
Hello,
Regards
Unfortunately, that's because the primitive is quite complex...
Incidentally, if you apply Eddybob's method, but set $$c=b^2\,$$, so that $$b=\sqrt{c}\,$$, you can take the constant outside of the square root... ;)
