Solving Carnot Heat Engine: Tf = SQRT(TcTh)
The discussion revolves around a heat pump and its relationship with a Carnot heat engine, specifically focusing on deriving the final temperature of the reservoirs as Tf = SQRT(TcTh). The problem involves concepts from thermodynamics and calculus.
  • The original poster attempts to manipulate equations related to heat transfer and efficiency but expresses confusion regarding the assumptions made, particularly about work and efficiency. Some participants suggest using calculus to find maxima or minima, questioning how to apply differentiation effectively in this context.
The discussion is ongoing, with participants exploring different mathematical approaches to the problem. There is a focus on differentiating equations to find maximum work output, but no consensus has been reached on the specific equation to differentiate or the implications of the results.
Participants are grappling with assumptions about work input and output, as well as the implications of setting efficiency to 1 for maximal work. There is an acknowledgment of potential confusion regarding the mathematical steps involved in the differentiation process.
Carlo09
A heat pump takes heat from a hot resevoir and dissipates heat to a cold one. Both resevoirs are equal mass and specific heat capacity. Show that as the heat engine does maximal work the final temp of the resevoirs = Tf = SQRT(TcTh)
Qin = Wout + Qout
mc(Th-Tf) = Wout + mc(Tf -Tc)
Efficiency = Wout/Win = 1- (Qin/Qout)
Well I know i somehow need to get TcTh^2 in order to get the solution so I used efficiecy as 1 for maximal work out but I also assumed no work in which means I'm dividing by 0! Or if I say 1= 1-Qin/Qout then Qout = 1-Qin and now I am just confused. Help please :)
Remember from calculus how to find the maximum (or minimim) of a function?
Are you meaning differentiate and set to 0 and then solve? Differentiate again and is D^2f(x)/Dx^2 < 0 then it's a maximum?
Yep, but you should only have to differentiate once. It should be pretty clear whether you have a max or min.
Thank you, Which equation do I differentiate?
Ooo right ok so I have dw/dQ_h = (T1-T2)/T1 = 0
therefore T1-T2 = 0 so T1=T2=T and so
dw/dQ_h = (T-T)/T which is 0 which doesn't help me :S
