Solving Concentration of Ammonium Phosphate in mol/L
  • Thread starter Thread starter Grove1996
    Concentration
The discussion revolves around determining the concentration of ammonium phosphate in mol/L based on measured concentrations of its products, ammonium (3NH4) and phosphate (P04). Participants explore the implications of the observed concentrations and the potential reactions affecting the original substance's concentration.
  • Homework-related
  • One participant seeks to find the original concentration of ammonium phosphate after measuring the concentrations of its products, noting discrepancies in the expected 3:1 ratio.
  • Another participant suggests that if the concentrations do not reflect the original composition, reactions may have consumed some of the original substance, complicating the determination of initial concentration.
  • Additional properties such as pH, total solids (TS), and total dissolved solids (TDS) are mentioned as potentially relevant but not fully explored.
  • Participants inquire about the type of probes used for measurement and the reasons for the deviation from the expected ratio.
  • One participant hypothesizes that the lower phosphate concentration could be due to precipitation by other elements like magnesium or calcium, or complexation with cations such as iron.
  • It is noted that the total concentration of ammonia is influenced by both ammonium ion concentration and pH, although pH below 8 may not significantly affect the results.
Participants express uncertainty regarding the initial concentration of ammonium phosphate and the reasons for the observed discrepancies. Multiple competing views and hypotheses remain without consensus on the underlying causes or solutions.
Limitations include the lack of clarity on additional properties of the system that could aid in determining the original concentration, as well as unresolved aspects regarding the reactions affecting the concentrations.
Grove1996
Hey
I have a problem on my hands, I'm trying to find the concentration of ammonium phosphate in mol/L.
Equation:
Excuse the badly written equation, I'm not quite sure on how to use subscrips/arrow signs on here.
(NH4)3P04 --------------- 3NH4 + P04
Known Data:
Mass of 3NH4 measured with probe = 400 mg/L (0.40 g)
Mass of P04 measured with probe = 10 mg/L (0.01 g)
Moles of 3NH4 = 0.0678 moles
Moles of P04 = 0.00009915 moles
The problem:
I have found the mass of each of the products using a probe. The 3:1 ratio is not existent and this is due to a number of reasons (ignore this). How do I determine the mass of the original substance put in. Once I know that I can find the morality quite easily. I've attempted it but my high school teacher said I was wrong. I added the masses and now when I look back, it was a stupid thing to do. I think I need to use the solubility of ammonium phosphate some how, the solubility in water is 58g/100mL
Any help would be much appreciated, I really am stuck.
If concentrations don't reflect the original composition, there are reactions that consumed some of the original substance. If so, in general you can't tell what was its initial concentration. Could be there are additional properties of your system that can be used to find the answer, but you haven't said anything about them.
Thanks for the reply. Yeah I understand what you are saying, my teacher told me to look into Le Chatelier's principle. As far as other properties go, I'm not quite sure what you mean. I have obtained other results through testing that might be of benefit. Such as the pH levels, TS (total solids) and TDS (total dissolved solids). Although, I'm not quite sure if that's what you were after. I'll keep researching though.
What kind of probe have you used, what are the reasons that you know about that made the ratio between ammonia and phosphate differ from 3:1?
To measure ammonium, an ammonium ion selective electrode was used. For phosphate, a colorimeter was used. As far the ratio, I'm assuming that there is something (some element in the water sample) that is causing the phosphate to be smaller than it should be. At least that is what I think. My teacher told me to look into what decreases the value for phosphate, but I haven't found anything yet.
Perhaps it was precipitated by Mg or Ca, or complexed some other cation (iron) that was present in water. Total concentration of ammonia is a function of both ammonium ion concentration and pH (although if you have pH below 8 it shouldn't matter much).
I'll research that up. Thanks for the help, I think I might know what to do now :).
  • · Replies 16 ·
