KF33
- 19
- 0
Graphing a) and b) might be helpful. What is the definition of continuity at a point?KF33 said:Homework Statement
The problem is posted below in the picture. I looked at c and d and can do those. I am unsure about a and b.
I looked at graphing the problems, but I think it is a wrong approach.
Continuity at a point: A function f is continuous at c if the following three conditions are met.Mark44 said:Graphing a) and b) might be helpful. What is the definition of continuity at a point?
For "a" I was thinking it can't be continuous because the graph would be broken up and you technically could not draw the graph without picking up your pencil.Mark44 said:You said you were unsure about parts a and b. What are your thoughts about these problems so far?
Mark44 said:For a) why is |f| continuous? For b) you say, "I was thinking 0." Can you elaborate on this? Try to be as clear as can about what you mean.
In your class has the definition of the limit been given yet? By that I mean the ##\delta - \epsilon## definition?
That's not what I asked about -- I asked what about |f|? Is it continuous?KF33 said:Attached is the definition about limits.
I think "a" is not continuous because the graph will be alternating between 1 and -1 and not stay at a straight line.
The problem doesn't involve s. Can you write something in more mathematical terms? I.e.,KF33 said:I would have to pick up my pencil to draw the graph.
For "b" I was thinking 0, because the limit as s approaches 0, the graph approaches 0.
For "b" I was thinking 0, because when you look at the limit you see the following.Mark44 said:That's not what I asked about -- I asked what about |f|? Is it continuous?
Also, since you have the limit definition to work with, why isn't f continuous anywhere? Can you say this in some way more rigorous than "picking up the pencil to draw the graph"?
$$\lim_{x \to 0} f(x) = ?$$
I used LaTeX to write this. In unrendered form this is $$\lim_{x \to 0} f(x) = ?$$
All of the functions listed in parts a through d are defined for all real numbers, so that's not the issue. What are they asking you in this problem?KF33 said:For "b" I was thinking 0, because when you look at the limit you see the following.
$$\lim_{x \to 0} f(x) = 0$$
So the function would be defined at that point.
The absolute value of the function, or |f|, is the one that is continuous. If you are given a value of ##\epsilon## would you be able to find a number ##\delta > 0## for which ##| |f(x)| - 0| < \epsilon## when ##|x - 0| < \delta##?KF33 said:For "a" I was thinking the absolute value function would be continuous, because I am thinking the -1 will change to positive 1.
Mark44 said:All of the functions listed in parts a through d are defined for all real numbers, so that's not the issue. What are they asking you in this problem?
Mark44 said:The absolute value of the function, or |f|, is the one that is continuous. If you are given a value of ##\epsilon## would you be able to find a number ##\delta > 0## for which ##| |f(x)| - 0| < \epsilon## when ##|x - 0| < \delta##?
More like the example you posted as an image, the one with the two sequences.KF33 said:Is this an idea of what you are getting at.
