Solving Diode Equation for Current?
  • Thread starter Thread starter physics_197
    Current Diode
8 replies · 3K views
physics_197
I need to find the current, but not sure how to rearrange the equation because of the I in the exp.
Thanks, just need to be pointed in the right direction. Seems like I will either be in ln or exp.
Also, just a follow up question, the diode ideality constant... Is there a way to solve for it? My notes just say its between 1 - 1.5, Should I just assume its 1? The manufacturers data sheet does not mention a value for this.
Because I appears on its own and as the argment of the exponential, you can't solve for it using elementary operations.
Are you talking about I0? That one you can solve for.
No, I'm talking about just I. So how would I go about finding it?
Using numerical methods
Thank you, I used Newtons method on matlab, I think it should be correct :)
Also, do any of you have an idea about the diode ideality factor? I am trying to model a PV module in Matlab and the data sheet does not mention this. I read online that people tend to assume its just 1... Any ideas?
Nevermind! After running through the code using different values (between 1 and 2), There is no difference in terms of the current... well either, it can be neglected or my code is wrong (I tried entering a large number, that affected the current)
Which variable is the diode ideality factor? That's what I was asking about in post #4.
