Solving Electric Problem: Q/q & Net Force on Particles
  • Thread starter Thread starter KyoPhan
    Electric
The discussion revolves around solving a problem involving four charged particles arranged in a square, focusing on the net electrostatic forces acting on them. For part (a), the user applies Coulomb's law to determine the relationship between charges Q and q, concluding that Q/q equals -2/a. In part (b), there is uncertainty about whether a charge q can equal Q with opposite signs to achieve equilibrium among the particles. The conversation also clarifies the significance of the diagonal distance in the square and confirms that "a" represents a distance measurement. Overall, the user seeks assistance in understanding the concepts and calculations related to electrostatic forces.
KyoPhan
My semester just started and I'm already struggling.
The diagram is a square with a dot on each corner representing a charged particle. 1 at top left, 2 at top right, 3 at bottom left, and 4 at bottom right. The distance on one side of the square is a
The problem reads In fig. 21-22, four particles form a square. The charges are q1 = q4 = Q and q2 = q3 = q.
(a) What is Q/q if the net electrostatic force on particles 1 and 4 is zero?
(b) Is there any value of q that makes the net electrostatic force on each of the four particles zero? Explain
For (a)
I think I have to apply Coulomb's law and calculate all the forces from each individual particle. Assuming that 1/4 are both negative and 2/3 are positive, I calculated the force upward (by adding the force caused between 1/4 and 1/3) on particle 1. Then I set them equal to 0. I solved for Q in relation with q and got Q = -2q/a . So I calculated Q/q and got -2/a.
For (b)
I want to say that q=Q but one of opposite sign because I remember my professor saying that if one charge is in equilibrium, then the rest are at well. (correct me if I'm using the terms or concept incorrectly). Or is this only when they are semetric because I remember him talking about it when there was a square with an electron on each corner, with a proton in the middle. Do I have the right idea or am I completely lost? Do I have to apply Coulomb's equation in some way?
Thanks you for taking your time, I really appreciate it.
Well, since Q and q are both quantities of charge, in [Coulomb],
is it possible that "a" has no units? Is "a" a distance, in [meter] ?
The horizontal component of Force on 1 must be zero ... so that :
kQq/a^2 = {kqq/(1.414 a)^2}sin 45 => Q/a^2 = .707q/(2a^2) ...
A has no units, its just an unknown distance
I'm sorry I'm kinda slow, but where did 1.414a come from?
It's the square root of two. Since we're dealing with a square, the length of the diagonal is s\sqrt{2}, where s is the side length.
O okay I understand it now, thanks a lot
sorry for late reply btw
