Solving for \(\theta\): A Geometry Refresher
  • Thread starter Thread starter PerryKid
    Geometry
PerryKid
Solve for [itex]\theta[/itex]
Diagram of a block on a 30 degree inclined plane, with a line through the block meeting a vertical reference line at angle theta, which is marked at the intersection.
Unknown
I know, but I have forgotten my basic geometry.
Hello.
You have a good start with the 60 degree angle that you identified. Try working with the red right triangle in the attachment.
  • Diagram of a box on a 30 degree incline with a vertical line through it, angle theta marked between the line and the incline normal, a 60 degree angle marked, and a red right triangle highlighted.
I wasn't sure if that was a right angle.
If so, then the entire problem was a piece of cake. If not, then it's more complicated than I thought.
I did make the assumption that the blue line shown is constructed to be a "normal line" (i.e., perpendicular to the slope). That's the usual case when working inclined plane problems.
However, if it is not given to be a normal line, then you can't find θ without additional information.
  • Diagram of a box resting on a right-triangle incline with a 30° angle at the base; a blue line runs perpendicular to the slope through the box, with angle θ marked between it and the vertical.
