Solving for Theta and Phi in Direction of Propagation | Homework Statement
  • Thread starter Thread starter guilesar
    Phi Theta
The discussion revolves around determining the angles theta and phi that characterize the direction of propagation in a given context involving spherical coordinates. The original poster presents a problem statement that defines the direction of propagation using specific equations relating Cartesian and spherical unit vectors.
  • Conceptual clarification, Assumption checking, Problem interpretation
  • Participants explore the definitions of the unit vectors and question the clarity of the original problem statement. Some express confusion regarding the relationship between the spherical coordinates and the Cartesian components provided.
The discussion is ongoing, with participants providing insights and questioning the assumptions made in the problem. Some guidance has been offered regarding the interpretation of the direction of propagation and the relationship between the unit vectors, but no consensus has been reached.
There are indications that the original problem may have been misinterpreted, with some participants suggesting that the coordinates provided might not align with standard conventions for representing position vectors. The complexity of the problem's wording is also noted as a potential source of confusion.
guilesar
The direction of propagation is defined as ex=sin(theta)cos(phi), ey=sin(theta)sin(phi), ez=cos(theta). What are the values of theta and phi characterizing the direction of propagation?
We have a point in space with the coordinates (r,theta,phi)=(2,3,4)
Components were defined in the problem.
Well, seeing as how the point is being designated by these numbers, and according to the spherical notation these numbers should represent theta and phi, I would think the answer would be theta=3 and phi=4. But that seems way too easy... so any guidance would be appreciated.
Thank you in advance!
what does ex,ey,ez mean. Use LaTeX!
This statement makes no sense to me. The equations \mathbf{\hat{e}}_x=\sin\theta\cos\phi\mathbf{\hat{e}}_r, \mathbf{\hat{e}}_y=\sin\theta\sin\phi\mathbf{\hat{e}}_{\theta},
and \mathbf{\hat{e}}_z=\cos\theta\mathbf{\hat{e}}_{\phi} simply relate the Cartesian unit vectors \{\mathbf{\hat{e}}_x,\mathbf{\hat{e}}_y,\mathbf{\hat{e}}_z\} to the spherical unit vectors, \{\mathbf{\hat{e}}_{r},\mathbf{\hat{e}}_{\theta},\mathbf{\hat{e}}_{\phi}\}
They do not define the direction of propagation of a particle or wave. However, any direction can be written in terms of either set of unit vectors.
What was the exact wording on your original problem statement?
This seems an unlikely way to give you a position vector...are you sure they don't mean (x,y,z)=(2,3,4)?
sorry, those are just elementary vectors. They could easily just be said x,y,z. I don't know what LaTeX is... :-p
This is just the second part of a four part problem. The original problem stated exactly as it was on my homework is:
A plane wave propagating in a given medium is expressed as
u(x,y,z,t)=u0exp[i(2x+3y+4z)*106-i1015t]
a. Find the given unit vector for the direction of propagation
A plane wave is generally described by:
expi[k*r -\omegat]
So the k vector is: (2,3,4) or k*r: 2x+3y+4z
the direction is (2x+3y+4z)/ (22+32+42) =2/(29)1/2x+3/(29)1/2y+4/(29)1/2.
The problem I originally stated is exactly what my worksheet says for part B.
expi[k*r -\omegat]
what happened to the factor of 10^6?
You should really use bolded letters, or something in order to denote vectors...Writing,
\mathbf{\hat{k}}=\frac{2}{\sqrt{29}}\mathbf{\hat{e}}_x+\frac{3}{\sqrt{29}}\mathbf{\hat{e}}_y+\frac{4}{\sqrt{29}}\mathbf{\hat{e}}_z
makes your intended meaning much clearer.
Okay, it seems like they are telling you (in a very confusing manner!), that the x, y, and z-components of the direction of propagation are \sin\theta\cos\phi, \sin\theta\sin\phi and \cos\theta respectively. If so, then you basically have:
\mathbf{\hat{k}}=\frac{2}{\sqrt{29}}\mathbf{\hat{e}}_x+\frac{3}{\sqrt{29}}\mathbf{\hat{e}}_y+\frac{4}{\sqrt{29}}\mathbf{\hat{e}}_z=\sin\theta\cos\phi\mathbf{\hat{e}}_x+\sin\theta\sin\phi\mathbf{\hat{e}}_y+\cos\theta\mathbf{\hat{e}}_z
and you are asked to solve for \theta and \phi
Yeah. I don't "forum" much so I just learned what Latex is tonight. But I'll work on it :)
Thank you very very much!
