Solving for x-Displacement of a Rolling Ball on an Inclined Track
The discussion revolves around calculating the x-displacement of a metal ball rolling down an inclined track. The problem involves parameters such as the ball's velocity, angle of inclination, and height of the track, with a focus on the kinematic equations relevant to projectile motion.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the initial conditions of the motion, including the velocity and angle, and question whether the initial vertical velocity is zero. There are attempts to derive time and displacement using various kinematic equations, with some participants expressing confusion over the signs of the values used.
The conversation is ongoing, with participants providing insights and corrections regarding the setup of the equations. Some have suggested alternative approaches to finding the velocity and time, while others are clarifying the implications of positive and negative values in their calculations.
There are indications of confusion regarding the signs of the velocity and acceleration due to the orientation of the track and the direction of motion. Participants are also navigating the constraints of the problem as presented in the homework statement.
goodz
a track is inclined in such way that the velocity of the metal ball is 60 cm/s at 25 degree below the horizontal. mathematically determine the total x displacement of the metal ball.
weight of ball: 65grams
height from floor to the end of the track: 76.15cm
velocity of the ball is 60.cm/s at 25 degree
[tex]\Delta[/tex]y =Vo*t - .5 1/2gt^2
Vx = Vox + .5at^2
I used the first equation to find time.
-76.15 = .5*-9.8t^2
t=.394s
deltaX = .6m/s*cos(-25).3942 + .5(-9.8).3942^2
i got delta X to be -54.7cm
is it suppose to be negative?
Could someone help me set this up right?
Hi goodz, welcome to Pf.
In the y direction the initial velocity is not equal to zero.
And in the x direction there is no acceleration.
I think i got it.
first i needed to get the velocity using v^2 = VoSin(-25)^2 - 2(-9.8).7615
v = 3.87m/s
then to get time,
3.87 = .6Sin(-25)-(-9.8)t
t=.4207
goodz said:
I think i got it.
v = 3.87m/s
then to get time,
t=.4207
If you take down as negative v, vi and g are all negative. So check the value of t.
are you saying .6m should be negative?
Allare positive or negative.
The equation should be
v = vosin(25) + gt.
3.87 = .6(sin25)+9.8t
t=.369s
x= voCos25t
x=.6cos25(.369)
x=.20m
  • · Replies 97 ·
12K
