Solving Force Problem: 2kg Ball Falling From 10m
The problem involves a ball of mass 2.0 kg dropped from a height of 10 m, with a focus on calculating the work done against air friction during its fall, given its speed just before impact.
  • Participants discuss the distinction between work and force, with some attempting to calculate work done against gravity and questioning the role of air resistance in the context of the problem.
Some participants have provided insights into the relationship between work and force, while others are exploring calculations related to gravitational work and kinetic energy. The discussion is ongoing with various interpretations being considered.
There appears to be some confusion regarding the definitions and calculations related to work, force, and energy, as well as the impact of air resistance on the ball's motion.
sheevz
Force Problem!
a ball of mass 2.0kg is dropped from a height of 10m. the speed of the ball is measured as 12.5m/s just before it hits the ground. what was the work done against air friction during this fall?
totally lost on where to begin can someone help me start? I am not finding anything on work itself as a force, is it a force?
Work is not force. Exerting a force is not the same as doing work.
Work = force*distance.
So in this case, Work = mg * 10m. See what that comes out to first.
Then, using some basic equations of motion, you want to work out what the speed of the ball would have been, neglecting air resistance. Now, we know what the actual speed was, accounted for air resistance. Then use the formula for kinetic energy to get you to the end =]
What is the work done against gravity my friend?
so if work is mg*distance
then would the work be 2.0kg*10m= 20kgm?
or 20J, now what is the actual kinetic energy of the ball at the bottom?
