Solving Hall Voltage Problem Homework Statement
The problem involves the Hall effect, specifically relating to the behavior of electrons in a conductor subjected to a magnetic field while carrying an electric current. The original poster seeks to establish relationships between electron velocity, current, electrostatic force, and Hall voltage based on provided experimental data.
  • Exploratory, Conceptual clarification, Problem interpretation
  • The original poster attempts to derive relationships involving electron velocity and current, as well as expressions for forces and Hall voltage. Some participants question the clarity of the problem statement and the necessity of visual aids for understanding.
The discussion is ongoing, with participants clarifying misunderstandings and suggesting resources for further exploration. There is no explicit consensus yet on the approach to solving the problem.
The original poster has provided specific experimental parameters, including current, dimensions of the conductor, and magnetic field strength, which are relevant to the problem but may require further exploration for complete understanding.
PhyBoy
[See the figure attached]
a) Find the relation between velocity of electron v and current I.
b) Because of the magnetic force on the electron they move at the edge of
conductor as shown in the figure and create a electrostatic force that oppomagnetostatic force. Find the expression for electrostatic force and magnetforce when they balance each other.
c) At equilibrium find an expression for Hall voltage V
in terms of magneelectron’s velocity v and width d.
H
Now, in a Hall-effect experiment, a current of 3.0 A sent lengthwise through a co1.0 cm wide, 4.0 cm long, and 10 mm thick produces a transverse (across the wpotential difference of 10 mV when a magnetic field of 1.5 T is passed perpendihrough the thickness of the conductor. From these data, find the number of elper unit volume of the conductor.
The Hall effect is the production of a voltage difference (the Hall voltage) across
an electrical conductor, transverse to an electric current in the conductor and a magnetic
field perpendicular to the current..The magnetostatic force acting on a moving charge passing through uniform magnetic field is given by,F = qvB. Where, B = magnetic field strength (unit Tesla), v =
velocity of charged particle that is perpendicular to the magnetic field lines. F is
perpendicular to both velocity and magnetic field.
Hall Voltage seems different from the normal textbook voltage problems that I have encountered. So, I couldn't make some satisfactory advancement.
Sorry, I didn't get you properly. But if you are pointing towards following the template I think I have done so. Uploading the photo is important to understand and solve the problem.
Thanks for your reply.
It would be very helpful if you point towards my mistake.what I have done again?
You haven't done anything wrong. The automated courtesy bump simply moved your thread back up the thread list to make it more visible to helpers. This occurs when a thread languishes without responses for period of time, so that it gets another chance to be considered by the helpers.
For your problem, I suggest that you take a look at the Hyperphysics website entry for hall effect.
Thanks for clarifying
  • · Replies 19 ·
  • · Replies 0 ·
