Solving higher order ODE as system of first order
The discussion centers on converting a higher-order ordinary differential equation (ODE) into a system of first-order equations. The approach involves defining a new variable, φ, as the derivative of θ, leading to a system where the second derivative of θ is expressed in terms of φ. The piecewise nature of the function u complicates the formulation, resulting in two distinct first-order equations based on the value of u. Initial conditions are specified for both θ and φ, but there is confusion about aligning these conditions consistently. The conversation emphasizes the need for clarity in defining the system and initial conditions to solve the ODE effectively.
gfd43tg
For this problem, I am stuck on the actual system. I don't see what substitution I can make, and the fact that ##u(v)## is a piece-wise function is tripping me up. How the heck do I approach this?? This doesn't look like a standard problem at all.
Actually, that's very much a standard problem- except perhaps that the function on the right, u, is much simpler than usual- it only has two values. No, you do not let "v=\theta" First, it isn't the independent variable you want to change to reduce the order and second, setting one variable equal to a new variable is just changing its name- not really changing anything.
Instead, let the new variable be equal to the derivative of \theta: \phi= d\theta/dt so that the second derivative of \theta is the first derivative of \phi- d^2\theta/dt^2= d\phi/dt. Now what does d^2\theta/dt^2= v(\theta) become?
okay,
Are these two my new system of two first order equations? They don't have to be derivatives with respect to the same variable?
\phi = \frac{d{\theta}}{dt}
\frac{d^2{\theta}}{dt^2} = \frac{d{\phi}}{dt}
Therefore,
\frac{d^2{\theta}}{dt^2} = u(\int \phi{dt}) ?
How do I specify the new initial conditions
Specifically:
##\frac{d \phi}{dt} = u(\int \phi(t) dt)##
Really there are two first order equations here. Do you see them?
I'm afraid I don't see them
You are given a specified piecewise function. It only has two values.
So does that mean the two equations are
\frac {d{\phi}}{dt} = -1 if ##u(\int \phi{dt}) \ge 0##
\frac {d{\phi}}{dt} = 1 if ##u(\int \phi{dt}) \lt 0##.
and if so, now how do I determine the new conditions?
Maylis said:
okay,
No, you put "\phi" in the wrong place!
\frac{d\phi}{dt}= u(\theta)
Therefore,
Your initial conditions were originally \theta(5)= \pi/2 and \theta&#039;(5)= \pi/10[/tex]<br /> so in terms of \theta and \phi[/tex] would be \theta(5)= \pi/2, \phi(5)= \pi/10.
HallsOfIvy,
So does that mean my two equation system is
##\frac {d{\phi}}{dt} = -1## if ##\theta \ge 0##
##\frac {d{\phi}}{dt} = 1## if ##\theta \lt 0## ??
with initial condition ##\phi(5) = \pi/10## and ##\dot{\theta}(5) = \pi/2##?? But then only one condition is in terms of ##\phi##, and the other in terms of ##\dot{\theta}##, is there a way to make the second one in terms of ##\phi##?
  • · Replies 33 ·
