Solving Inequality: -∞ < a < -3 ∨ -1 < a < ∞
  • Context: High School
  • Thread starter Thread starter andreask
    Inequality
4 replies · 2K views
andreask
Hi
I'm trying to solve this inequality
|1/(2+a)| < 1.
1/(2+a) < 1 ∨ 1/(2+a) > -1
1 < 2+a
a > -1
and
1 > -2-a
3 > -a
a > -3
I know that the boundaries are
What have I done wrong?
thanks in advance
Mathematics news on Phys.org
|1/(2+a)|-1<0, result of adding -1 to both sides.Examine two conditions separately. The case, 2+a>=0, and the case, 2+a<0. Follow each solution process separately.
I can't think in advance if they will be conjoint or disjoint, but you'll find out once both conditions are solved.
Be aware, the expression 2+a must not be allowed equal to zero, meaning a<>-2;
so -2 is a critical value.
andreask said:
Hi
|1/(2+a)| < 1.
The connector above should be ∧ ("and") rather than "or".
If |x| < b, then an equivalent inequality is -b < x < b. This is what you should have done here.
andreask said:
1 < 2+a
When you multiply both sides by 2 + a, are you multiplying by a positive number or a negative number? It makes a difference as regards the inequality symbol.
andreask said:
a > -1
and
1 > -2-a
3 > -a
a > -3
thanks in advance
The case with the negative sign should read 1/(2+a) < -1. Take absolute value on both sides is equivalent to changing sign on both sides, which requires reversing the inequality direction.
For an alternate approach
[tex] \begin{align*}<br /> -1 & < \frac 1 {2+a} < 1 \\<br /> -(2+a)^2 & < (2+a) < (2+a)^2 \\<br /> -a^2 - 4a - 4 & < 2+a < a^2 + 4a + 4 \\<br /> -a^2 - 5a - 6 & < 0 < a^2 + 3a + 2 \\<br /> -\left(a^2 + 5a + 6\right) < 0 < a^2 + 3a + 2 \\<br /> -(a+3)(a+2) < 0 < (a+1) (a+2)<br /> \end{align*}[/tex]
Solve the right inequality, solve the left inequality. The solution is the intersection of the two parts.
