Solving Linear Equations: Inconsistent, Dependent & Independent
The discussion focuses on solving systems of linear equations and determining whether they are inconsistent, dependent, or independent. Participants emphasize that converting equations to slope-intercept form (y=mx+b) is not necessary for solving the systems or identifying their characteristics. One user provides a solution for the first equation, highlighting that the result is a point rather than a slope. The conversation reveals confusion about the requirement for slope-intercept form, with suggestions to focus on solving the equations directly instead. Overall, the key takeaway is that understanding the nature of the systems is more important than converting them to slope-intercept form.
torid
solve each system of linear equations. Indicate whether each system is inconsistant, dependent, or independent.
i'm not sure how to get these problems into slope intercept form: y=mx+b
1.
3x - 6y=9
1/2x=y +3/2
2.
2x + 3y=1
-3x + 4y=-10
3.
0.5x - 0.75y=0.125
4x-6y=12
if anyone could explain to me how to do these problems, that would be great.
i just don't understand how to get them into slope.
but i do get how to graph them.
You don't get them into slope-intercept form. You just solve them or show you can't. Solve one equation, for example, for x and substitute that expression into the other equation.
yeah. but i do need them in slope intercept form, so maybe you could explain how i get them there.
No, you don't get need them in slope intercept form. I'll give you a big hint, the solution to the first one is x=6, y=3/2. That's a single point. You don't express that in slope intercept form. It's a POINT. Now, how did I get that solution?
Please explain why you need to get them in slope intercept form? If the problem requires you to do that, why didn't you say so in your first post? You said the problem was to "Indicate whether each system is inconsistant, dependent, or independent"! That has little to do with "slope intercept" form. And, I should point out that "problem" don't have a slope intercept form so it is unclear what you mean by "get these problems into slope intercept form"!
If you mean get each equation into slope intercept form (again, not necessary for doing what you first said you wanted to do nor even a good idea), you say, correctly, that slope intercept form is "y= mx+ b". Do you notice the "y" alone on the left side? Solve each equation for y. If you know what slope intercept form is, or are working on systems of equations, you certainly should know how to solve a single linear equation.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
