Solving Log Equations: Proving LHS = RHS
  • Thread starter Thread starter songoku
    Log
14 replies · 4K views
songoku
[tex]1. \frac{x^{log~7x^2}}{7 x^{log~4x}}=7^{log_2 2~-1}[/tex]
[tex]2. 100 x^{log x~-1}+x^{log_2 x ~-2}=20000[/tex]
The RHS = 1, so xlog 7x2 = 7 xlog 4x
Stuck...
2. Completely dunno...
:frown:
PS: log is not natural logarithm
Stuck...
:frown:
For the first one, so far so good.
Next step: take logs of both sides. Use the laws of logs to manipulate everything till it becomes a quadratic equation in log(x) and logs of constants only. Let m = log(x) and solve the quadratic the usual way.
Haven't had time to look at the second one yet.
Stuck...
:frown:
So ...
What are you supposed to do?
What is the problem statement as it was given to you?
Also, if log is not the natural logarithm, what does log represent?
(log 7x2)(log x) = log 7 + log 4x. log x
(log 7 + 2 log x)(log x) = log 7 + (log 4 + log x)(log x)
Let m = log(x), then:
(log 7 + 2m) m = log 7 + (log 4 + m) m
m log 7 + 2m2 = log 7 + m log 4 + m2
m2 + (log 7/4) m - log 7 = 0
Using quadratic formula to solve for m will give a not very nice result and I don't know how to get the value of x from that
SammyS said:
So ...
The problem is to solve the equation, i.e find the x satisfies the equation.
log is logarithm with base 10
For the first one, I suggest multiplying both sides by 7, then
combine exponents on the left side.
[itex]\displaystyle \frac{x^{\log~7x^2}}{ x^{\log~4x}}=7\cdot7^{\log_2 2~-1}[/itex]
[itex]\displaystyle x^{\log~7x^2-\log~4x}=7\cdot7^{\log_2 2~-1}[/itex]
Simplify the right side. Take the log10 of both sides.
The right side will be 7 and after taking log10 of both sides I get the same result as above: m2 + log(7/4) m - log 7 = 0
Did I make any mistakes?
You have the right equation. Are you expecting a "nice" answer? In any case, you can still manipulate the result to get you a value in terms of logs, it's just not very "nice".
Yeah I am expecting nice answer, although the correct answer may not be nice :biggrin:
So the answer will be:
x = 10^(the result of quadratic formula)
Pretty much. I haven't really tried simplifying it too hard, but I checked at least the positive root (after taking the antilog) and it's definitely the correct solution.
If you have access to Maple/Mathematica, you can try and see if you can get it to a nice form. Then you know whether it's worth trying to expend effort working towards it. :biggrin:
OK. What about the second one?
No insights yet, I'm afraid. Just to be clear, could you confirm that the exponent on the first term is a common log (base 10), while the one on the second term is a base-2 log? And the first term is multiplied by 100?
Doesn't look tractable (for an exact solution) if that's the right question. But I'll think about it some more.
Yes you are correct. I can assure you that I type the question correctly. I also think that this question can't be solved.
Maybe you can propose a revision for this question? I mean, change the question a little bit to make it solvable. :D
If you change the second problem to
$$100x^{(\log x) - 1}+x^{(\log x^2) - 2} = 20000$$it becomes solvable.
Yes, that one's very easy. Almost immediately becomes a quadratic in [itex]x^{\log x - 1}[/itex]. Discriminant is a perfect square too, so nice solutions.
[itex]x^{\log x - 1} = N[/itex] can be reduced to another quadratic in [itex]\log x[/itex] by rearranging and taking logs of both sides. Easy peasy.
Thanks vela, for "revising" the question. :smile: Hopefully, songoku will now chime in and say that's what he meant all along. :biggrin:
Here I come ! :biggrin:
Unfortunately, I typed the correct question that was given to me :-p But for now, let's assume that vela's version is how the question should be :smile:
Thanks a lot for the help Curious, Sammy and vela o:)
