Solving Logic Function w/ NOR Gates
8 replies · 4K views · last reply
theuniverse
Consider the truth table below.
(a) Write an expression for the logic function that it represents, and simplify that expression as much as possible, showing all steps.
(b) Draw a logic circuit implementing this.
(c) Redesign your circuit to use only NOR gates.
A B C Q(output)
0 0 0 0
0 0 1 0
0 1 0 1
0 1 1 0
1 0 0 0
1 0 1 0
1 1 0 1
1 1 1 0
a) I chose to concentrate on when Q has values of 1. so I came up with the following equation: (where ~ means not, ie. ~A means that A is false)
Q = ~AB~C + AB~C
= B~C(~A+A) [~A+A=1]
= B~C
b) See attached.
c) that's where I could use some help... I'm not really sure how to write an expression or change my circuit diagram using what I already have.
Thanks!
  • Logic circuit diagram: input C feeds an inverter labelled inverter, and its output and input B feed an AND gate whose output is labelled AND.
Do you know De Morgan's laws? They should help you work this out.
(A + B)' = A'B'
(AB)' = A' + B'
Try drawing logic gates for each of those and they'll show you how else your function could be represented.
I drew them, and I see how something can go from AND to NOR for examples but I still don't understand how I can break BC' into something that I can draw using only NORs.
If I put the whole expression like so: (BC')' would I be able to do anything with it?
Remember that you can make an inverter out of a NOR. Put one of its inputs to 0 and it will invert the other input.
I think I get it. I will need to use 1 NOR for my inverter, and 3 NORs for my AND, am I right?
You can do better. Think about applying DeMorgans law to your BC'.
Using two NOR gates: BC'=B''C'=(B'+C)'.
So one of my NOR gates is used to invert the B, and then the other one connects the B' and a C which makes it equal to (B'+C)'.
Would that be correct?
Looks good to me. You can always check what the output your circuit gives.
