Solving Op-Amp with Feedback - Get Help Here!
  • Thread starter Thread starter birdy_uk
    Feedback Op-amp
The discussion revolves around the analysis of an operational amplifier (op-amp) circuit with feedback components, specifically focusing on the role of resistors and capacitors in filtering and signal amplification. Participants explore various aspects of the circuit's behavior, including its filtering characteristics, AC coupling, and the implications of different configurations.
  • Some participants suggest that the feedback configuration involving resistors and capacitors serves a filtering purpose, potentially filtering out high frequencies.
  • Others propose that the circuit acts as a high-pass filter or a bandpass filter, depending on the arrangement of components and their interactions.
  • One participant notes that the output is AC coupled, which removes the DC offset from the sensor signal, while another emphasizes the importance of the feedback capacitor in maintaining stability and gain characteristics.
  • Several participants discuss the implications of the circuit's design on its ability to amplify AC signals without amplifying the DC offset, with varying interpretations of how the components interact.
  • A participant presents a transfer function derived from the circuit, indicating a complex relationship between the components and their frequency response, while acknowledging that further analysis is needed to fully understand the system.
  • Some participants express uncertainty about the role of specific components, such as the output RC series, and its impact on the overall circuit behavior.
Participants do not reach a consensus on the exact nature of the filtering characteristics or the overall function of the circuit. Multiple competing views regarding the filtering type and the implications of the feedback components remain present throughout the discussion.
Participants mention various assumptions about ideal op-amp behavior, the significance of component values, and the potential effects of load impedance on circuit performance. There are also references to the need for further calculations and analysis to clarify the circuit's behavior.
birdy_uk
Hope someone might be able to help, if you look at the circuit attached. Why is the feedback of resistor and cap not being fed to ground? What purpose does this serve. I was thinking its probably to filter out unwanted high frequencies but unsure??
Thanks
Hello,
It seems to me that the system is doing some sort of filtering.
To know what type of filtering, you can write the transfer function from input (sensor input) to output (voltage after capacitor C3).
The output is AC coupled, this removes the DC offset of the sensor signal at the output.
Assume ideal opamp.
In the very high frequency case the caps are shorts, so IC1 acts like a voltage follower. The whole thing acts like a voltage source whose output is V(3) and has a 10k impedance.
In the DC case the caps are opens. This is kind of a weird case and the final settling voltage is probably going to be dependent on the intial conditions of node 2 and 6 but I think in general IC1 will be able to make nodes 2 and 3 equal (V(C2,6)=V(3) V(C1,R1,R3)=0 thus I(R1,R3)=0 and everything is stable and IC1 is a follower).
So IC1 is a notch filter and the whole thing is a high pass filter?
At a first glance it looks like a integrator ;) But, actually C in parallel with R is used to control the bandwidth of the amplifier so without c2 it will be a non-inverting low-pass shelving amplifier, but together with a C2 & R it makes it a high-pass shelving amplifier, so i say it is a bandpass!
Other than that capacitors in parallel with a feedback resistor are often used to improve the speed of a comparator, for instance, by increasing the amount of feedback at high frequencies.
Initially I thought bandpass too but I think it will pass a DC signal, so then it wouldn't be bandpass. Also, I think one wants IC1 to pass DC so the AC coupling stage has a bias point.
Anyway, I'll just wait for someone else to do the math. I should really be working on my own circuits. ;)
Actually, now I think Antoker is right.
I was thinking that it was trying to remove middle frequencies from the signal.
But now that I really look at it I think the IC1 stage amplifies signals in a band by 1+R3/R1 and just passes everything else as a copy (i.e. unity gain at very high and low frequencies). And the R2 and C3 stage serves as AC coupling.
It looks to me like it is made to amplify an AC signal that has a DC offset on it but at the same time NOT amplify the DC offset.
it's a filter. C3 is large and basically a DC blocking cap. as long as the output is conneted to a decently high-impedance input, i would not worry about R2 and C3. if not (and the input impedance of whatever it is that your output is connected to is in the ballpark of R2) you will have to know that input impedance to get a complete analysis of the circuit.
now combine C1 and R3 together into a common impedance (call it ZF, "F" for "feedback") using impedances in parallel and combine C2 and R1 (in series) into a common impedance called Z1. then it is just a linear op-amp circuit in non-inverting configuration and the (frequency dependent) gain is 1 + ZF/Z1 (with the gain at DC being 0 due to C3).
That is quite obvious, especially if you look at the output stage, since it includes a capacitor, hence the dc is being blocked, so it doesn't matter if there is a dc offset.
Basically I remembered how each of shelving filters look like, and since they are together that makes a bandpass filter, as long as a HP stage comes first. I have not done any calculations either, I'm just too tired :zzz:
And another thing I've noticed, what's the point of a rc-series at the output? Is it to match opamp to the load at the specified frequency? It just can't be a simple dc-block, since input of the opamp is not biased at one half of the psu, by a divider and there is no virtual ground.. brrr, nevermind just thinking out loud :rolleyes:
Ok, I wasn't too tired anyway, so I've written a transfer function for this amplifier s-domain, excluding output rc-series circuit, here is what a came up with:
I started with a normal transfer function for typical non-inverting amp, replaced resistive parts with a complex impedances, re-arranged and then I came up with the following transfer function:
[tex]H(s) = \frac{1+10.2\cdot s + 0.1\cdot 10^{-1} \cdot s^{2}}{(1+0.1\cdot s)\cdot(1+\frac{1}{10}\cdot s)}[/tex]
Then, since it is hard to analyze this function by inspection I ported it to MATLAB and got a bode-plot for the function, here is a result.
Still it looks, like a bandpass, since I didn't include the output stage so it won't be a correct result, since rc-series will introduce an additional zero/pole to the system.
Antoker, I was not referring to C3 on the output. That is most obviously a DC blocking capacitor. I was referring to C2 making the feedback 100% for DC which puts whatever DC voltage that is on the + input on the output. C3 doesn't do much for you if the DC gain of the amplifier causes the output to go to the power supply rail. This is why C2 is there. Technically yes it does form a bandpass filter because C1 offers more negative feedback as the frequency goes up. I would guess the gain approaches 1 at a frequency less than 5 to 10 hertz, maybe less. Not sure what the high end is, by just looking at it I'm sure the gain drops below 1 before you get to 300 hertz. One reason for R2 being there might be because opamps don't work well with capacitive loads. We have no idea what this thing drives so one assumption would be to have a series resistor there to prevent a capacitive load to ground from causing the opamp to go into oscillation.
Concerning the output stage, I would guess that the large resistor will swamp any Xc the capacitor contributes within the passband. If you included the output stage I doubt it would look much different.
Averagesupernova, sorry, my bad. :) Yeah, I think also that output rc, won't do much about the gain/frequency response of the opamp.
