Why Do Parallel Wires with Currents Attract or Repel Each Other?
  • Thread starter Thread starter ankur29
    Currents
Parallel wires with currents attract each other when the currents flow in the same direction and repel when they flow in opposite directions. The magnetic field generated by one wire exerts a force on the other wire, which can be determined using the right-hand rule to find the field direction and the left-hand rule to find the force direction. Users express confusion about applying these rules correctly, particularly in visualizing the magnetic fields and forces involved. Diagrams and external resources, such as Hyperphysics, are recommended for better understanding. Mastery of these concepts is essential for proving the behavior of currents in parallel wires.
ankur29
I've read that when currents in two parallel wires are going in the same direction, they attract each other. The same text said that when the currents are going in opposite directions, the two wires repel each other. now i can't porve this for myself as i keep making the folowing mistake
can someone have a look at what i doing worng?
please forgive my spelling
http://img29.imageshack.us/img29/7831/currentinwiresattarctor.th.jpg
For proof see Smythe "Static and Dynamic Electricity" 2nd Ed, Sec 7.19 and 8.01. Take derivative of stored energy. Opposite currents repel.
Don't think in terms of "polarity". The magnetic field from one wire exerts a force on the second wire. Use the right hand rule to find the direction of that magnetic field, then use it again to find the direction of the force that it exerts on the current in the second wire.
Here is a demo:
are you speaking of right hand grip rule? do you mean flemings left hand rule if not how would i use grip rule it to find the force? even so if both the wires are carrying current in same direction right next to each othe rmy thumb points in same direction as do my fingers curl in same direction i.e magnetic field lies in same direction :S
sorry if i just sound ignorant/stupid ,i just can't cant get my head around it
ps thanks for all the quick replies
Yes, use the right hand grip rule or the corkscrew rule or whatever you prefer to find the field direction around one of the wires.The field due to that wire is at 90 degrees to the current in the second wire.Now use the left hand rule to find the force direction on the second wire.
Here's a diagram of the right hand rule for finding direction of magnetic force.
Sorry if I wasn't clear. (And thanks to jtbell for providing helpful hyperphysics links.) I always use a "right hand" rule for everything. Makes it simpler (at least to me). To find the direction of the magnetic field from a straight current-carrying wire, use the right hand "grip" rule. Here's an illustration: http://hyperphysics.phy-astr.gsu.edu/HBASE/magnetic/magcur.html#c1"
Once you find the magnetic field from wire 1 that acts on wire 2, then use a different version of the right hand rule to find the force. (See the links provided by jtbell.) This is equivalent to Fleming's left hand rule, of course.
I didn't even know there was a left-hand rule until seeing this thread. I've always used my right hand for everything. And all the textbooks I've used so far have mentioned only right-hand rules.
I don't like using those hand rules.They make me look like a total muppet.
  • · Replies 32 ·
  • · Replies 29 ·
9K
  • · Replies 36 ·
