Solving Partial Differential Equation
The discussion focuses on solving the partial differential equation (PDE) $$u_{xy}=2yu_x$$ for the function $$u(x,y)$$. The solution is expressed as $$u(x,y)=e^{y^2}f(x) + g(y)$$, where $$f$$ and $$g$$ are arbitrary functions. The user successfully applies the substitution $$u_x = f$$, leading to the ordinary differential equation (ODE) $$f_y = 2 y f$$, which facilitates finding the solution. This approach demonstrates the relationship between PDEs and ODEs, providing a clear method for tackling similar problems.
  • Understanding of partial differential equations (PDEs)
  • Familiarity with ordinary differential equations (ODEs)
  • Knowledge of function substitution techniques
  • Basic skills in solving differential equations
  • Study the method of characteristics for solving PDEs
  • Learn about separation of variables in PDEs
  • Explore the application of the Fourier transform in solving differential equations
  • Investigate the use of boundary conditions in PDE solutions
Students and professionals in mathematics, physics, and engineering who are working with differential equations, particularly those seeking to deepen their understanding of solving partial differential equations.
Peter Alexander
1. The problem statement, all variables, and given/known data
Task requires you to solve a partial differential equation $$u_{xy}=2yu_x$$ for ##u(x,y)##. A hint is given that a partial differential equation can be solved in terms of ordinary differential equations.
According to the solution sheet, the result should be ##u(x,y)=e^{y^2}f(x) + g(y)## where ##f,\:g## seem to be two arbitrary functions.
I don't think there are any relevant equations to explicitly mention.
I believe that a solution to the task hides somewhere in the example I've solved before. Given a partial differential equation $$u_{xx}=0$$ which has to be solved for ##u(x,y)##, I've simply assumed that $$u(x,y) \rightarrow u(x)$$which evidently produced a second order linear homogeneous ODE. Then, I would simply use ##u(x)=e^{ax}## and its second order derivative to find a general solution ##u(x,y) = c_1(y)+xc_2(y)##.
If I would want to produce the same ODE in my example, then I guess I should be looking at the partial derivatives and what they have in common. I can see that both sides of the equation include a partial derivative with respect to ##x##, so can I make a substitution ##u_x = v## or something like that?
But a problem with this approach is t
I am stuck solving this task. I would like to ask for some help, but I do not expect anyone to solve my homework instead of me. Instead, all I'm asking for is some guidance or tips I can use to solve the task myself.
PS: I hope you're having a wonderful Monday!
Try calling the function ##u_x = f##. Then the equation reduces to the ODE ##f_y = 2 y f##. Solve this for f(y), then plug this back into ##u_x = f## to get the x dependence.
Thank you so much! I actually managed to find a solution this way, thanks!
