Solving Possion's equation: electrostatic potential
7 replies · 4K views
LocationX
I have the problem and my work uploaded to this webpage. I believe I have the general idea down, but I'm just afraid that I've done a careless calculation and missed a minus sign somewhere. I feel that my results have a lot of negative signs, making the potential constantly negative. I'm not sure if this is what is expected. Any help is appreciated.
http://sites.google.com/site/physicsinc/phy
You've made an error when applying the boundary conditions:
[tex]{\varphi}_{I}(R)={\varphi}_{II}(R), \quad {\varphi}_{II}(R+d)={\varphi}_{III}(R+d)[/tex]
You've for some reason interchanged your constants [itex]C_0[/itex] and [itex]C_1[/itex] with [itex]C_3[/itex] and [itex]C_4[/itex]; you can't do this.
You have 4 unknown constants to solve for, so you will need 4 boundary conditions. Luckily, [itex]\varphi[/itex] isn't the only thing that is continuous; [itex]\vec{E}(r)=\vec{\nabla} \varphi[/itex] must be continuous as well. This should give you your other two boundary conditions.
[tex]{\varphi}_{I}(r)=C_1^I[/tex]
[tex]{\varphi}_{II}(r)=-\frac{4 \pi r^2 \rho }{6} + \frac{C_0^II}{r}+C_1^II[/tex]
[tex]{\varphi}_{III}(r)=\frac{C_0^{III}}{r}[/tex]
[tex]{\varphi}_{I}(R)=C_1^I[/tex]
[tex]{\varphi}_{II}(R)=-\frac{4 \pi R^2 \rho }{6} + \frac{C_0^II}{R}+C_1^II[/tex]
[tex]{\varphi}_{II}(R+d)=-\frac{4 \pi (R+d)^2 \rho}{6} + \frac{C_0^II}{R+d}+C_1^II[/tex]
[tex]{\varphi}_{III}(R+d)=\frac{C_0^{III}}{R+d}[/tex]
[tex]\frac{d {\varphi}_{I}{dr} |_{r=R} = 0[/tex]
[tex]\frac{d {\varphi}_{II}{dr} |_{r=R} = \frac{8 \pi R \rho }{6} - \frac{C_0^{II}}{R^2}[/tex]
[tex]\frac{d {\varphi}_{II}{dr} |_{r=R+d} = \frac{8 \pi (R+d) \rho }{6} - \frac{C_0^{II}}{(R+d)^2}[/tex]
[tex]\frac{d {\varphi}_{III}{dr} |_{r=R+d} = - \frac{C_0^{III}}{(R+d)^2}[/tex]
We use the 4 B.C.:
[tex]{\varphi}_{I}(R) = [tex]{\varphi}_{II}(R)[/tex]<br /> [tex]{\varphi}_{II}(R+d) = {\varphi}_{III}(R+d)[/tex]<br /> [tex]\frac{d {\varphi}_{I}{dr} |_{r=R} = \frac{d {\varphi}_II}{dr} |_{r=R}[/tex]<br /> [tex]\frac{d {\varphi}_{II}{dr} |_{r=R+d} = \frac{d {\varphi}_III}{dr} |_{r=R+d}[/tex]<br /> <br /> I've already caught 2 minus sign errors... but this is how I'm setting up everything to solve for the 4 constants.[/tex]
Why not write it as:
[tex]{\varphi}_{I}(r)=C_0[/tex][tex]{\varphi}_{III}(r)=\frac{C_1}{r}[/tex]
[tex]{\varphi}_{II}(r)=-\frac{4 \pi r^2 \rho }{6} + \frac{C_2}{r}+C_3[/tex]
to get rid of those cumbersome superscripts and make it a little easier to work with?
You are still missing a couple of negative signs:
[tex]\frac{d {\varphi}_{II}}{dr} |_{r=R} = -\frac{8 \pi R \rho }{6} - \frac{C_0^{II}}{R^2}[/tex]
[tex]\frac{d {\varphi}_{II}}{dr} |_{r=R+d} = -\frac{8 \pi (R+d) \rho }{6} - \frac{C_0^{II}}{(R+d)^2}[/tex]
What do you get for your constants now?
You are missing a negative sign for C_2, which is affecting your other constants.
thanks for the help, I'm confident that i do not have any more errors after solving for the e-field and checking the BC and limiting cases
