Solving Second-Harmonic Generation Phase Mismatch - Exact Solution?
  • Context: Graduate
  • Thread starter Thread starter andonrangelov
    Generation Phase
8 replies · 4K views
andonrangelov
Hi All,
I was searching in the net if the exact solution of the nonlinear system describing the second harmonic generation does exist, but I found nothing.
Does some one know about such solution and if yes can you give references? Thanks
Well it seems that my question is very difficult …..
Ok, here is the nonlinear system that I want to solve
idA/dt=B.B.exp(i.s.t)
idB/dt=B*.A.exp(-i.s.t)
where B(t),A(t),s=constant but B and A are complex (B* means complex conjugation of B in the above equation)
Nonlinear differential equation can, what are the solutions of this one?
Hi all,
I am searching for the solutions of the following nonlinear system:
where B(t),A(t),s=constant but B and A are complex (B* means complex conjugation of B in the above equation). Does some one know its solutions?
I know the solution in case when s=0 then B(t)=tanh(t); A(t)=i.sech(t), but I do not know the more general case. Can you help me?
Thanks
What about is s is very small? I.e. when [itex]0<s\ll 1[/itex], you can get an analytical solution then, by expanding the exponential as [itex]\exp (x)=1+x[/itex].
Mat
It seems to me that something is wrong here. Your B(t)=tanh(t); A(t)=i.sech(t) is not a solution to your system when s=0. Or I misunderstand your notations.
I didn't check this, if s=0, then you can divide the equations to find:
[tex] \frac{dB}{dA}= \frac{A}{B}[/tex]
Which integrates to [itex]A=kB[/itex], where k>0 is the integration constant, substuting this into the second equation shows that:
[tex] i\frac{dB}{dt}=kB^{2}[/tex]
Which certainly doesn't give the solution that you have.
