Qbit42
- 45
You are given in a earlier stage of this problem that the wavefunction is separable, ie.)
\Psi(x,y) = X(x)Y(y)
The problem asks you to solve for the wavefunction of a particle trapped in a 2D infinite square well using Parity. ie.) solve
\Psi(-x,-y) = \Psi(x,y) and \Psi(-x,-y) = -\Psi(x,y).
The potential is defined by U(x,y) = 0 if -a \leq x \leq a and -b \leq y \leq b and infinite everywhere else.
Since the wavefunction is separable I just solved the 1D infinite square potential for both X(x) and Y(y). The results are:
X(x) = ACos(\frac{n\pi x}{2a}) for n odd and X(x) = ASin(\frac{n\pi x}{2a}) for n even
and Likewise for Y(y)
My question is can I just combine these two results together to get the parity solutions for the total wavefunction?
\Psi(x,y) = ACos(\frac{n_{x}\pi x}{2a})Cos(\frac{n_{y}\pi y}{2b}) n_{x} odd, n_{y} odd
\Psi(x,y) = ASin(\frac{n_{x}\pi x}{2a})Sin(\frac{n_{y}\pi y}{2b}) n_{x} even, n_{y} even
\Psi(x,y) = ACos(\frac{n_{x}\pi x}{2a})Sin(\frac{n_{y}\pi y}{2b}) n_{x} odd, n_{y} even
\Psi(x,y) = ASin(\frac{n_{x}\pi x}{2a})Cos(\frac{n_{y}\pi y}{2b}) n_{x} even, n_{y} odd
Is this correct?
