Solving Steel Beam Design Problem - Get Help Now!
  • Thread starter Thread starter mariechap89
    Beam Design Steel
The discussion revolves around solving a steel beam design problem, focusing on calculations related to loads, including dead loads from concrete and reinforcement, and live loads. Participants seek assistance with their calculations and understanding of how to incorporate various loads into the design process.
  • Homework-related
  • One participant expresses concern about a calculation yielding a maximum design load that seems excessively large, indicating a possible error in their calculations.
  • Another participant points out the lack of defined parameters and units in the original calculations, suggesting that this contributes to confusion regarding the results.
  • There is a discussion about the correct unit weight of concrete and steel, with one participant correcting the unit weight used in the calculations.
  • Participants discuss the importance of including the weight of the steel beam in the calculations, with some suggesting it may be ignored for certain calculations.
  • One participant shares revised calculations for the dead load, but still finds the resulting value to be too large, indicating ongoing uncertainty about the calculations.
  • Another participant provides detailed calculations for the uniformly-distributed load (UDL) and suggests how to apply it to the beam design.
  • There is a query about how to handle a point load in conjunction with a UDL, indicating a need for clarification on this aspect of the problem.
  • One participant shares their calculations for point loads on a girder and seeks guidance on how to incorporate these into the overall design, particularly in relation to the UDL from the concrete deck slab.
  • Another participant suggests a method for calculating the factored point load at a specific point on the beam, indicating a potential approach to resolving the design problem.
Participants do not reach a consensus on the calculations, as multiple competing views and uncertainties remain regarding the correct approach to the problem and the values used in calculations.
Participants express uncertainty about the inclusion of certain loads and the correct application of formulas, indicating that assumptions about load types and definitions may vary. There are unresolved mathematical steps and dependencies on specific definitions that affect the calculations.
Students and professionals involved in structural engineering or civil engineering design, particularly those working on beam design and load calculations.
mariechap89
Hi.
I have started to do this question (the question it's self is attached with it's relevant diagrams) but I am coming up with a too large a maximum design load, the value I am looking for isn't on the tables I have so I must have made a calculation error somewhere. Any help would be much appreciated.
Here is what I have so far:
Volume of concrete slab= (6x6x0.175)=6.3m^3
Volume of reinforcement= 6.3 x 1.25% = 0.07875m^3
Total Volume= 6.37875m^3
G=(6.3x24.0) + (24.0 + 0.04725 x 0.07875)
=153.09kN/m^3
Q= 2.8 kn/m^3 given with the question
WL^*=(1.2G+1.5Q)x span x spacing
=(1.2x153.09+1.5x2.8)x6x3
=3382.34 kN
Which is a rather large number so I must be going wrong somewhere.
mariechap89: You did not define the parameters you are using for your G calculation; and you did not include units in that calculation. Therefore, we do not really know what you are doing in your G calculation. Next time, you should define the parameters, and/or include units.
You have the wrong units on the live load. Read the given problem statement more carefully.
The volume of concrete per unit area is (1 m)(1 m)(0.175 m)/[(1 m)(1 m)] = 0.175 (m^3)/(m^2). Multiplying this by 24.0 kN/m^3 gives (24.0 kN/m^3)[0.175 (m^3)/(m^2)] = 4.200 kN/m^2. By the way, the specific weight of steel is gamma = 77.0 kN/m^3, not 24.0 kN/m^3.
Also, always leave a space between a numeric value and its following unit symbol. E.g., 6.3 m^3, not 6.3m^3. See the international standard for writing units[/color] (ISO 31-0[/color]).
Thanks for your help, I realize I have got the calculation very wrong not even including the weight of the steel beam. I am pretty sure we are supposed to ignore the self weight of the beam for these calculations. I'm not sure how to use the weight of the concrete slab in the calculation for the steel beam sizing. Anyhelp would be great thanks.
mariechap89: The concrete dead load is in post 2. Finish that calculation by adding the reinforcement steel weight per unit area to it. After you obtain the factored dead plus live load per unit area, multiply it by spacing; i.e., multiply it by the width of the area supported by beam CD. This will give you a uniformly-distributed load, w, along the beam, in units of kN/m. Analyze the beam using the applied, uniformly-distributed load, w.
Here is what I have now:
Volume of concrete= 6x6x0.175=6.3 m^3
Then the unit weight for concrete, dense aggregate, un-reinforced from a table is 24.0 kN/m^3 and then adding 0.6 for each 1% by volume of steel reinforcement the unit weight is 24.6015 kN/m^3.
Therefore G= 6.3x24.6015= 155 kN/m^2
I am given Strength limit state: WL=1.2G+1.5Q
Therefore WL=(1.2x155)+(1.5x2.8)x6x2= 2282.4 kN
Which, is still too large a value.
Also How would I handle the second part of the question ? I know how to handle a point load to find the steel beam size but how do I handle a point load and a udl ?
Thanks
See posts 2 and 4 to find out how to do this.
G = (24.0 kN/m^3)[(0.175 m^3)/(m^2)] + (77.0 kN/m^3)[0.0125(0.175 m^3)/(m^2)] = 4.200 kN/m^2 + 0.1684 kN/m^2 = 4.3684 kN/m^2.
Therefore, WL = 1.2*G + 1.5*Q = 1.2*(4.3684 kN/m^2) + 1.5*(2.8 kN/m^2) = 9.4421 kN/m^2.
Now multiply load by width supported by beam CD, to obtain the uniformly-distributed load, w, on beam CD.
w = WL*spacing = WL*(1.5 m + 1.5 m) = (9.4421 kN/m^2)(3 m) = 28.326 kN/m.
Or, if you want to use the table value (adding 0.6 kN/m^3 for each 1 % of steel), that would be as follows.
gamma = 24.0 kN/m^3 + (0.6 kN/m^3)*1.25 = 24.7500 kN/m^3.
G = (24.7500 kN/m^3)[(0.175 m^3)/(m^2)] = 4.3313 kN/m^2.
Therefore, WL = 1.2*G + 1.5*Q = 1.2*(4.3313 kN/m^2) + 1.5*(2.8 kN/m^2) = 9.3976 kN/m^2.
w = WL*spacing = (9.3976 kN/m^2)(3 m) = 28.193 kN/m.
Hi.
Thanks for your help, this stuff is finally starting to make sense.
I understand how you've done the calcs for part a of the question and am pretty sure I know where I was going wrong.
I'm not too sure how to handle part b of the question though ??
You can compute the load supported by (coming down on) point D, which gives you just a point load at the midspan of beam MN.
Hi
I have calculated the point loads on the girder MN (Ithink). I have used a 310UB40.4 beam. So 40.4 kg x 6 m = 242.4 kg
242.4 kg/2 = 121.1 kg (Asthe girder only supports half the weight of the beams)
121.1 x 9.81 = 1188.0 N = 1.188 kN
And there would be 3 point loads at 3m apart as girder MN supports 3 beams.
Assuming I have done this right, how ould I caluclate G from here including the udl from the concrete deck slab ?
Thanks
mariechap89: The factored UDL for beam CD is w in post 6. The factored point load at point D would be w*(0.5*LCD) + 1.2(1.189 kN), where LCD = length of beam CD = 6 m.
Your professor might let you ignore the point loads at points M and N, because they are virtually at the supports, causing virtually no moment on girder MN.
  • · Replies 23 ·
10K
12K
11K
