Solving Tennis Physics: Force & Acceleration
8 replies · 3K views
Meowserkitty
A tennis racket (950 g) hits a tennis ball (110 g) with a force of 5000 N. What is the acceleration of the tennis ball? During the collision, with what force does the tennis ball hit the tennis racket? What is the acceleration of the tennis racket? (Remember that force and acceleration are vectors, so be careful with positive and negative signs. Assume the player let's go of the racket just after contact.)
f = m*a
5000=110a
a) 45.4 m/s2
b) -5000 N
c) 5000=950a
-5.3 m/s2
Hi Meowserkitty
Be careful with your units, 1N=1Kg/s²
oli4 said:
Hi Meowserkitty
Nope, 1N=(1kg(m))/s2
Also, whenever you see collisons, that just begs momentum. (p=mv)
Your answer was way too simplistic. Physics is (almost) never that easy, unfortunately.
Ah yes, sorry I forgot the m because I was looking at putting the bold tag around Kg first :)
Could you explain how I should go about this? Our physics teacher was gone all week and could not help us.
You just have to transform the mass expressed in g as expressed in Kg, that is, you divide it by 1000 :)
Other than that do I do the same thing I did? And would the rackets acceleration be negative?
We are not doing momentum yet
Yes, you are :)
Maybe you didn't call it this way in class, but the Newton's law you are using is
"the force is the rate of change of momentum"
F=d(mv)/dt
As far as you are/will be concerned for a while, mass is constant, so that becomes
F=mdv/dt=ma :)
