- 14,826
- 4,810
haruspex said:What height above the circle's centre does the bead start? How high is it above the circle's centre when it has moved angle theta around the circle? h is the difference of the two.
Yes! Now plug that into find Fn. Next, determine the forces on the ring.SuperHero said:h = R - Rcosθ
SuperHero said:So this is what i get:
mgcosθ + Fn = 2mg (R -Rcosθ) / R
Rmgcosθ + RFn = 2mgR - 2mgRcosθ
RFn = 2mgR - 3Rmgcosθ
RFn = (R) 2mg - 3mgcosθ
Fn = 2mg - 3mgcosθ
tada!
haruspex said:Good. So the forces on the ring are? And when you have that, at what angle theta is the tension minimised?
SuperHero said:So the forces on the big ring are the 2 normal forces by the beads and the force of gravity. For the θ, r u supposed to know or calculate?
TSny said:Remember that the forces acting on the ring add together as vectors. So, you need to consider the vertical components separately from the horizontal components.
Careful with the direction of Fn. As a force on the bead, you took the positive direction to be towards the centre of the circle. We're now dealing with the reaction force of the bead on the ring, so the direction is reversed. (But I see you have done that in the equation below.)SuperHero said:Alright so for the vertical component of the ring we have
the two 2(Fn) towards the middle
and the Fg as well as the tension so.
2(Fn = 2mg - 3mgcosθ) + T = Fg
No, Fn is neither vertical nor horizontal. It has a vertical component. What is the magnitude of that vertical component?SuperHero said:ok so if the Fn is not a vertical force. the equation would become T = Fg
haruspex said:No, Fn is neither vertical nor horizontal. It has a vertical component. What is the magnitude of that vertical component?
Yes. So now write your equation with T, Fn, θ and Fg again.SuperHero said:it if Fncosθ
haruspex said:Yes. So now write your equation with T, Fn, θ and Fg again.
Yes, but substituting what you already worked out for Fn.SuperHero said:2(Fncosθ) + T = Fg
haruspex said:Yes, but substituting what you already worked out for Fn.
The next thing is to find out for what values of Fg the tension, T, becomes 0 at some point during the movement of the beads.
How do you think we might do that?
No! You have your equation: T = Fg - 2Fncos(θ) = Fg - 2mg(2-3cos(θ))cos(θ). Do you get that? It really bothers me that having come this far you would suggest T = Fg.SuperHero said:So wouldn't the tension have to be the same as the gravity Fg force
haruspex said:No! You have your equation: T = Fg - 2Fncos(θ) = Fg - 2mg(2-3cos(θ))cos(θ). Do you get that? It really bothers me that having come this far you would suggest T = Fg.
Let's look at some values here. When θ = 0, T = Fg+2mg (correct). When θ = π/2, T = Fg (correct). When θ > π/2, T > Fg. But perhaps somewhere between 0 and π/2, T < Fg. How might we find the most interesting value of θ?
haruspex said:It could be, or it could be something else. We want to know whether T can reach zero, right? And in particular we want to know the largest Fg for which T can reach zero. So of all the values of 2mg(2-3cos(θ))cos(θ), which one are we looking for?
Not sure what you intended Fg to include, but based on the equations it is only the weight of the ring. That's how it should be. Any contribution from the beads comes in via Fn.SuperHero said:The Fg of the ring? which includes the ring and the beads
haruspex said:Not sure what you intended Fg to include, but based on the equations it is only the weight of the ring. That's how it should be. Any contribution from the beads comes in via Fn.
So, to recap, we have T = Fg - 2mg(2-3cos(θ))cos(θ), and we want to know the largest Fg for which T goes as low as 0 for some theta. We can turn that around and ask what's the lowest T for a given Fg? I.e. for a given Fg, what value of theta will make T go lowest?
Theta has to be at least 1 what? Radian? How do you work that out? Never mind.SuperHero said:Well the Fg has to be a bit bigger than T, so the value of theta has to be atleast 1 to be allow the tension to be smaller than fg right?
Oh. I have no idea how you are supposed to solve this problem without differentiation to find a maximum value.SuperHero said:I have calculus next semester though
haruspex said:So, to recap, we have T = Fg - 2mg(2-3cos(θ))cos(θ), and we want to know the largest Fg for which T goes as low as 0 for some theta.
