Solving Trigonometric Equations
  • Thread starter Thread starter BlackOut07
    Trigonometric
This discussion focuses on solving trigonometric equations related to a pendulum's motion and the current in a household appliance. The pendulum's angular displacement is modeled by the equation Ɵ=1/4sin((pi/2)t), and participants are tasked with determining the times when the pendulum is displaced 1 cm vertically above its rest position within the first 4 seconds. Additionally, the current is described by A=5sin(120pit), with users attempting to calculate the rate of change at t=1s. The correct approach involves using calculus for the current's rate of change, specifically applying the limit definition of a derivative.
  • Understanding of trigonometric functions and their properties
  • Familiarity with calculus concepts, particularly derivatives
  • Ability to work with radians in trigonometric equations
  • Graphing skills to visualize trigonometric functions
  • Study the limit definition of a derivative for calculating rates of change
  • Learn how to apply trigonometric identities to solve equations
  • Explore the relationship between angular displacement and vertical displacement in pendulum motion
  • Practice graphing sine functions to identify key points and behaviors
Students studying precalculus and calculus, physics enthusiasts analyzing pendulum motion, and anyone looking to improve their problem-solving skills in trigonometric equations.
BlackOut07
1) When a pendulum 0.5m long swings back and forth, its angular displacement Ɵ from rest position, in radians is given by Ɵ=1/4sin((pi/2)t), where t is the time, in seconds. At what time(s) during the first 4 s is the pendulum displaced 1 cm vertically above its rest position? (assume the pendulum is at its rest position at 0).
2) the current in a household appliance varies according to the equation A=5sin120pit, where A is the current in amperes, and t is the time, in seconds. at what rate is hte current changing at t=1s?
1) I'm not sure how to approach/solve this question
2) i got 0, can anyone confirm?
Start by sketching a graph. At what points on the graph is the height above the starting position 1 cm?
Show us how you got 0.
a=(5sin120pi(1))-(5sin120pi(0.999))/(1-0.999)
=0?? doesn't make sense though
What you have calculated here is the current at t = 1. Is the question not asking for the rate of change at t = 1?
so would it be
a=(5sin120pi(1.001))-(5sin120pi(0.999))/(1.001-0.999)
Yes, that's a pretty close approximation and will give you an answer within 2.35 % of the exact answer. Question, have you ever done any calculus before? (and yes, I do realize this is the precalculus section)
gordonj005 said:
Yes, that's a pretty close approximation. Question, have you ever done any calculus before?
no, i have it second semester.
and the answer is STILL 0 :/
I assure you the answer is not zero, make sure your calculator is in radian mode, and make sure you keep track of your negatives.
the maximum of this graph is 0.25 :/
i got the answer as a=-328.365.
For the pendulum, think in terms of trigonometric functions. If you set the rest position to (0, 0) and you know the radius is 0.5 m, for what values of \theta will the height be 1 cm? Once you figure that out, you can find the times fairly easily.
Ok so:
m = \frac{5 \sin{120\pi 1.001} - 5 \sin{120\pi 0.999}}{0.002}
m = 2500(\sin{120.12 \pi} - \sin{119.88 \pi})
where \sin{120.12 \pi} \approx 0.368 and \sin{120\pi 0.999} \approx -0.368. I think if you try again you'll get the right answer.
i still don't understand to be honest :/
  • · Replies 32 ·
