Solving trigonometry equation involving half-angle
  • Thread starter Thread starter songoku
    Trigonometry
42 replies · 5K views · last reply
songoku
Please see below
Double angle formula
Equation: 7 cos(θ/2) = 10 sin θ, for 0 ≤ θ ≤ 2π.
I can solve this by using the double-angle formula but the teacher expects another method not involving the double-angle formula.
Is there a way to solve this without using double-angle formula?
Thanks
You can start with the trig identity
##\sin(a+b)=\sin a \cos b+\cos a \sin b##
and set ##a=b=\dfrac{\theta}{2}.##
You can also iterate numerically.
That’s just giving the double angle formula though.
Without it I would go for the complex exponential solution mentioned by fresh.
I thought about that, but the quoted trig identity can be derived directly using complex exponentials without invoking the double angle formula. Regardless of how one goes about solving this, one will have to use the given fact that the argument of the trig function on the left is half the argument of the trig function on the right.
Sure, but it is the double angle formula once you put both arguments to theta/2.
In general however, I do find it silly to prohibit certain paths to solve a problem unless there is very good reason to do so.
I agree. Prohibiting paths raises the question whether what is not explicitly prohibited is implicitly allowed. If using WolframAlpha is not prohibited, for example, then it can be used.
What class is this in and what level of school is it?
songoku said:
Homework Statement:: Please see below
Relevant Equations:: Double angle formula
Thanks
$$\frac{7}{\sqrt{1+t^2}}=10\times \frac{2t}{1+t^2}$$
Yes, but how do you derive this expression for the tangent ##t## of the half-angle without using the half-angle formula on the right-hand side?
I thought that not using the double angle meant not solving: $$7\cos\left(\frac{\theta}{2}\right)=20\cos\left(\frac{\theta}{2}\right)\sin\left(\frac{\theta}{2}\right)$$ which would be straight forward.
See reply #7 by @Orodruin. I agree with him that this is silly and I have said all I had to say here.
Iterate on your calculator $$\theta = sin^{-1}\left(\frac{7}{10} cos(\frac{\theta}{2})\right)$$ until it converges.
I asked the teacher for clarification about another method he expected then he sent me a pdf email containing a lot formulas. For trigonometry part, the formula is only sine and cosine rule.
I am starting to think this is a troll rather than a serious question. I just don't see how the question is related to sine and cosine rule.
Is it just me or there is actually a way to solve this question using sine and cosine rule?
Thanks
You could try the special angles you know sines and cosines of without wasting time on ones that obviously won't work like x=0.
Thank you very much for the help fresh_42, kuruman, bob012345, Orodruin, neilarpker62, epenguin
This looks to me like a reasonable path toward a solution.
It probably should be pointed out that in the right hand side, the tangent half-angle formula is used for ##\sin \theta##, where ## t=\tan (\theta / 2) ## . See https://en.wikipedia.org/wiki/Tangent_half-angle_formula
In the left hand side, ##\cos(\theta / 2)## is expressed in terms of ## \tan (\theta / 2) ##.
Thanks
Hand-drawn isosceles triangle in orange with two sides labelled 10 and base labelled 7, and the apex angle marked theta in green.
neilparker62 said:
Wow, there is really a way to solve the question using the sine and cosine rule. :redface:
Thank you very much for the help neilparker62
You could even drop a perpendicular and solve by elementary trig! After which we have come full circle since:$$ \cos\left(\frac{\theta}{2}\right)\left(20\sin\left(\frac{\theta}{2}\right)-7\right)=0.$$
For benefit of the weaker brethren, can songaku or someone please spell out the arguments – both methods? I am not seeing it.
There are three solutions 0 ≤ θ ≤ 2π . One of them you can obtain as indicated in #16 (and you may kick yourself if you have missed it).
Actually the periodicity of the problem is 4π not 2π (Another reason for doubt as to whether the Prof who set it knew exactly what he's about) and there are two of these 'trivial' solutions, and still only two others 0 ≤ θ ≤ 4π , I think.
By both methods, do you mean the methods in post #19 and post #22?
If yes, for the method in post #19:
$$7 \cos \left(\frac{\theta}{2}\right)=10 \sin \theta$$
$$\frac{7}{\sin \theta}=\frac{10}{\cos \frac{\theta}{2}}$$
$$\frac{7}{\sin \theta}=\frac{10}{\sin \left(\frac{\pi}{2}-\frac{\theta}{2}\right)}$$
This is in the form of sine rule and then I changed it into triangle diagram to get the same picture as post#19
Solving the cosine rule, I got 0.72 and 5.57 as the solution. I got the third solution by using your method in post #16For the method in post #22, I used the double angle formula (which is maybe prohibited by my teacher):
$$7 \cos \left(\frac{\theta}{2}\right) = 10 (2 \sin \frac{\theta}{2} \cos \frac{\theta}{2})$$
$$7 \cos \left(\frac{\theta}{2}\right) - 10 (2 \sin \frac{\theta}{2} \cos \frac{\theta}{2})=0$$
$$ \cos\left(\frac{\theta}{2}\right)\left(7-20\sin\left(\frac{\theta}{2}\right)\right)=0$$
Solving this, I got all the three solutions
How do you get this from the diagram which has only one angle solution?
To @songoku:
To elaborate on @bob012345's statement, if you want to use the triangle, you need to provide a geometrical proof. Hint: You need to find two line segments, one of length ##7 \cos \left(\frac{\theta}{2}\right)## and one of length ##10 \sin \theta## and show that they are equal.
The solution to the second bracket is that which you can get either by dropping a perpendicular and using elementary trig or by applying sine rule to the triangle I drew. In the latter case, I would say the solution ##\cos(\frac{\theta}{2})=0## is excluded since ##\cos(\frac{\theta}{2})## would be a denominator in the equation ##\frac{7}{\sin\theta}=\frac{10}{\cos(\frac{\theta}{2})}##. But we can of course solve for ##\theta## directly in the triangle by applying the cosine rule.
kuruman said:
To @songoku:
Sorry I don't really understand your hint.
What I did was only change sine rule into triangle:
Side of length 7 will be across the angle ##\theta## and side of length 10 will be across angle ##\frac{\pi}{2} - \frac{\theta}{2}##. One more angle of the triangle will be ##\frac{\pi}{2} - \frac{\theta}{2}## so the triangle is an isosceles triangle and the third side will also be 10.
But the solution of ##\cos(\frac{\theta}{2})=0## satisfies the original question so wouldn't we lose one solution if we exclude that?
Thanks
Here is what I had in mind. The diagram is drawn to scale specifically for this problem but the proof is general because the proposition that we are asked to prove is an identity.
Isosceles triangle ABC with apex A at top and base BC horizontal. Dashed altitude AF drops from A to F on BC. Dashed line BD runs from B to point D on side AC. Angles marked alpha at A on either side of AF, and beta at B between BD and BC.
  1. Draw isosceles triangle ABC.
  2. Draw heights AF and BD.
  3. From right triangle ADB we have ##BD = AB \sin(2\alpha).##
  4. From right triangle AFB BDC we have ##BD = BC \cos(\beta).##
  5. It follows that ##AB \sin(2\alpha)=BC \cos(\beta).##
  6. Angles ##\alpha## and ##\beta## are equal because their sides are mutually perpendicular. Therefore, ##BC \cos(\alpha)=AB \sin(2\alpha).##
  7. Setting ##\alpha = \frac{\theta}{2}##, ##AB=10## and ##BC=7## finishes the proof for this specific case.
