Solving trigonometry equation involving half-angle
  • Thread starter songoku
    Trigonometry
42 replies · 5K views · last reply
SammyS said:
It looks like this is for triangle BDC not AFB .
Good catch! I made the necessary correction. Thanks.
songoku said:
But the solution of ##\cos(\frac{\theta}{2})=0## satisfies the original question so wouldn't we lose one solution if we exclude that?
Thanks
Perhaps we should rather say it's a trivial solution since 7 x 0 = 10 x 0.
Well, it's a trivial solution if you use the double angle formula for sine in the equation given in the OP.
It's also apparent that it's a solution if you note that ##\cos\left(\frac \theta 2 \right)=0## for ##\theta## being an odd multiple of ## \pi ## and that ##\sin\left ( \theta \right )=0## for any integer multiple of ##\pi## .
kuruman said:
Here is what I had in mind. The diagram is drawn to scale specifically for this problem but the proof is general because the proposition that we are asked to prove is an identity.
  1. Draw isosceles triangle ABC.
  2. Draw heights AF and BD.
  3. From right triangle ADB we have ##BD = AB \sin(2\alpha).##
  4. From right triangle AFB BDC we have ##BD = BC \cos(\beta).##
  5. It follows that ##AB \sin(2\alpha)=BC \cos(\beta).##
  6. Angles ##\alpha## and ##\beta## are equal because their sides are mutually perpendicular. Therefore, ##BC \cos(\alpha)=AB \sin(2\alpha).##
  7. Setting ##\alpha = \frac{\theta}{2}##, ##AB=10## and ##BC=7## finishes the proof for this specific case.
Sorry, for step no. 6, what is the meaning of "their sides are mutually perpendicular" ?
Thanks
Thanks
Angle ##\alpha## (right) is formed by segments AF and AC.
Angle ##\beta## is formed by segments BD and BC.
BD is perpendicular to AC and BC is perpendicular to AF. That's what "mutually perpendicular" means. You can see that the sides will be parallel to each other when you rotate AF and AC counterclockwise by 90° which makes the angles equal.
Thanks
Alternatively: Notice that triangle AFC and triangle BDC are similar, so ##\alpha = \beta ## .
Thank you very much for the help and explanation kuruman, neilparker62, SammyS
We should not deny ourselves the insights that graphs give – here both Cartisian and polar presentations.
Graph of two sine-type curves against x with labelled axis ticks at -2π, 2π, 4π and 6π and y-axis from -15 to 15: a red curve with amplitude 10 and a blue curve with amplitude 7, both crossing zero at the same points.
https://www.physicsforums.com/attachments/314377
Polar graph on a graphing calculator screen showing a red curve with two loops and a blue cardioid-like curve, with angle labels from 0 to 11π/6 and radial scale marks from -10 to 10.
The first gives, I think, some extra clarification on the two 'zero' roots. But there is something that still eludes me. I would expect by a change of variable to e.g. (π - θ) to get a symmetrical expression with a perfect square, so that the solutions are ± the same quantity. I have not been able to do this and need to go back to school - maybe I have arrived at the right place.
Maybe it is not possible to get an equation involving perfect square and the ± solutions are due to the symmetry of the trigonometry function?
It seems to me that ##\cos(\frac{\theta}{2})=0## is not a solution to a particular equation. The identity $$2\cos(\frac{\theta}{2})\sin(\frac{\theta}{2})=\sin(\theta)$$can be derived geometrically from the triangle ABC in post #30 shown slightly modified below.
Isosceles triangle ABC with apex A; dashed altitude AF to base BC, with equal angles alpha at A on each side; dashed segment BD to side AC, with angle alpha at B between BD and BC.
We have
  1. ##(BC)=2(BF)=2(AB)\sin(\alpha)\implies (BC)\cos(\alpha)=2(AB)\sin(\alpha)\cos(\alpha)##
  2. ##(BD)=(AB)\sin(2\alpha)=(BC)\cos(\alpha)##
From 1 and 2 it follows that $$(AB)\sin(2\alpha)=2(AB)\sin(\alpha)\cos(\alpha)\tag{1}$$which proves the identity. Being an identity means that it is not an equation to be solved and that it has no roots. It means that if you put any specific value of ##\alpha## in each side and evaluate separately, you get ##LHS=RHS##. That's not how equations with roots behave.
When ##\alpha##, which is the same as ##\frac{\theta}{2}##, is equal to 90° we have
##LHS=(AB)\sin(2\times 90^o)=(AB)\sin(180^o)=(AB)*0=0.##
##RHS=(AB)\cos( 90^o)\sin( 90^o)=(AB)*0*1=0.##
It is a solution to the original equation stated in the OP.
( Graphs )
Yes, the graphs are very helpful.
I'm not sure about what you mean by getting a symmetrical expression with a perfect square. As for the change of variable to (π - θ):
Letting ##\gamma = (\pi - \theta )## gives the following.
##\displaystyle 7\sin(\dfrac \gamma 2 ) = 10 \sin(\gamma), \text{ where } -\pi\le \gamma \le \pi \ . ##
This version of the equation does have some nice symmetry.
It was only a vague preliminary working suspicion: since there are various trigonometrical identities involving squares I suspected the solution might involve a quadratic equation. These have two solutions. If you choose the origin appropriately you get a perfect square. I was trying to find one by a geometrical construction.
The oversight, you could call it, is that squaring is not the only function that is 1:1 but has a non-unique inverse - as pointed out by songaku #39.
I first looked for simple known standard angles and hit on almost immediately
θ = π .
I could not find any construction relating 7/20 to some standard known angle, so did the same derivation of the equation
$$cos(θ/2)(7-20sin(θ/2))=0 $$
as Neilparker #12 or songaku #25.
This equation is satisfied by θ = π as already realized. Additionally we have to find solutions that satisfy
$$7-20sin(θ/2)=0 $$
These have not been explicitly stated yet here. The solutions for θ are
θ = 2 sin-1(7/20)
My function plotter gives me a graph like this for the function sin-1
Graph of y = arcsin(x) on a calculator screen, passing through the origin and rising from (-1, -π/2) to (1, π/2), with the x-axis marked -2, -1, 1, 2 and the y-axis marked -2, -1, 1.
(and at school before we had such things my tables only went up to 90° or π/2 radians).
But we know we have to extend the range and will get two values as we see in here.
Graph of x = sin(y/2) type curve plotted on a grid, drawn in three colored segments: green near the origin, purple in the middle, and blue at the top; x-axis labeled -2 to 2, y-axis labeled 1 to 6, with the curve wrapping back and forth between x = -1 and x = 1.
In this case if ##x## is a solution then ##(π - x)## is another solution. In the present case I get solutions approximately θ = 0.7151 and 5.568.
I think if I had solved it by just writing formulae without plotting graphs I would not have noticed the second solution. Isn't it a bit worrying that such an oversight could be a small part of a computer program or of these 300 page long proofs that mathematicians do these days?
