- 15,937
- 9,117
Good catch! I made the necessary correction. Thanks.SammyS said:It looks like this is for triangle BDC not AFB .
The discussion revolves around solving a trigonometric equation involving half-angle identities. The original poster seeks alternative methods to the double-angle formula, which is typically used to approach such problems.
The conversation is active, with multiple participants offering different perspectives on how to approach the problem. Some guidance has been provided regarding potential methods, but there is no explicit consensus on a single approach. The discussion reflects a mix of interpretations and attempts to clarify the teacher's expectations.
There is uncertainty regarding the teacher's restrictions on methods, leading to confusion about the relevance of certain trigonometric rules. Participants express skepticism about the connection between the problem and the sine and cosine rules, indicating a potential misalignment in expectations.
Perhaps we should rather say it's a trivial solution since 7 x 0 = 10 x 0.songoku said:But the solution of ##\cos(\frac{\theta}{2})=0## satisfies the original question so wouldn't we lose one solution if we exclude that?
Thanks
Well, it's a trivial solution if you use the double angle formula for sine in the equation given in the OP.neilparker62 said:Perhaps we should rather say it's a trivial solution since 7 x 0 = 10 x 0.
Sorry, for step no. 6, what is the meaning of "their sides are mutually perpendicular" ?kuruman said:Here is what I had in mind. The diagram is drawn to scale specifically for this problem but the proof is general because the proposition that we are asked to prove is an identity.
- Draw isosceles triangle ABC.
- Draw heights AF and BD.
- From right triangle ADB we have ##BD = AB \sin(2\alpha).##
AFBBDC we have ##BD = BC \cos(\beta).##- It follows that ##AB \sin(2\alpha)=BC \cos(\beta).##
- Angles ##\alpha## and ##\beta## are equal because their sides are mutually perpendicular. Therefore, ##BC \cos(\alpha)=AB \sin(2\alpha).##
- Setting ##\alpha = \frac{\theta}{2}##, ##AB=10## and ##BC=7## finishes the proof for this specific case.
Angle ##\alpha## (right) is formed by segments AF and AC.songoku said:Sorry, for step no. 6, what is the meaning of "their sides are mutually perpendicular" ?
Thanks
Alternatively: Notice that triangle AFC and triangle BDC are similar, so ##\alpha = \beta ## .songoku said:Sorry, for step no. 6, what is the meaning of "their sides are mutually perpendicular" ?
Thanks
Maybe it is not possible to get an equation involving perfect square and the ± solutions are due to the symmetry of the trigonometry function?epenguin said:The first gives, I think, some extra clarification on the two 'zero' roots. But there is something that still eludes me. I would expect by a change of variable to e.g. (π - θ) to get a symmetrical expression with a perfect square, so that the solutions are ± the same quantity.
It is a solution to the original equation stated in the OP.kuruman said:It seems to me that ##\cos(\frac{\theta}{2})=0## is not a solution to a particular equation.
Yes, the graphs are very helpful.epenguin said:We should not deny ourselves the insights that graphs give – here both Cartisian and polar presentations.
( Graphs )
The first gives, I think, some extra clarification on the two 'zero' roots. But there is something that still eludes me. I would expect by a change of variable to e.g. (π - θ) to get a symmetrical expression with a perfect square, so that the solutions are ± the same quantity. I have not been able to do this and need to go back to school - maybe I have arrived at the right place.
SammyS said:I'm not sure about what you mean by getting a symmetrical expression with a perfect square.
