Calculate Charge on Catfish Parallel Plate Capacitor
  • Thread starter Thread starter hotstuff
The discussion focuses on calculating the charge generated at each end of a catfish modeled as a parallel plate capacitor. The capacitance is calculated using the formula C = ε₀ * k * A / d, resulting in a value of 1.51 x 10^-11 Farads. When multiplied by the voltage of 350 V, the charge is determined to be approximately 5.3 x 10^-9 Coulombs, which aligns with the answer provided in the reference book. The discrepancy in the initial calculations was attributed to careless errors in the capacitance computation.
  • Understanding of parallel plate capacitor theory
  • Familiarity with the formula for capacitance: C = ε₀ * k * A / d
  • Knowledge of charge calculation using Q = C * V
  • Basic understanding of dielectric materials and their constants
  • Review the principles of capacitance in parallel plate capacitors
  • Study the impact of dielectric materials on capacitance
  • Practice calculations involving capacitance and charge using different dielectric constants
  • Explore the applications of capacitors in biological systems
Students studying physics, electrical engineers, and anyone interested in the electrical properties of biological systems, particularly in relation to capacitors and dielectrics.
hotstuff
(c=keA/d
(b) Estimate the charge generated at each end of a catfish as follows: Treat the catfish as a parallel plate capacitor with plates of area 1.8 * 10-2 m2, separation 1. m, and filled with dielectric with a dielectric constant k = 95. with v=350. ans should be in C
seems easy enough but no getting the same ans at the back of the stupid book. this is what i have done so far.
find capacitance of parallel plate capacitor= c=keA/d = 8.85*10^-12*95*1.8*10m^2/1 = ans
and then use the q=cv= above ans*350 the back of the book is 5.3*10-9, i am getting 5.0 *10^-13 what is really good. any help appreciated
hotstuff said:
(c=keA/d
your approach is correct. book is also correct. check for careless errors.
Capacitance \ = \ \frac{(95)(8.85 \, \times \, 10^{-12})(1.8 \, \times \, 10^{-2})}{1.0} \ = \ 1.51 \, \times \, 10^{-11} \, Farads
Charge \ = \ Capacitance \, \times \, Voltage \ = \ (1.51 \, \times \, 10^{-11}) \, \times \, (350) \ = \ 5.29 \, \times \, 10^{-9} \, Coulombs
Firstly, it is important to note that the formula for capacitance is C = ε₀ * k * A / d, where ε₀ is the permittivity of free space (8.85 * 10^-12 F/m). So, the correct calculation for the capacitance of the catfish parallel plate capacitor would be:
C = (8.85 * 10^-12 F/m) * 95 * (1.8 * 10^-2 m^2) / (1 m) = 1.5 * 10^-8 F
Next, to calculate the charge on each end of the catfish, we can use the formula Q = C * V, where Q is the charge, C is the capacitance, and V is the voltage. In this case, the voltage is given as 350 V. So, the charge on each end would be:
Q = (1.5 * 10^-8 F) * (350 V) = 5.3 * 10^-6 C
This is the same answer as the one given in the back of the book. It seems like you may have made a mistake in your calculation for the capacitance, which led to the incorrect answer. I hope this helps!
  • · Replies 18 ·
  • · Replies 21 ·
