Some questions about electromagnetism
  • Level: Graduate
  • Thread starter PainterGuy
    Electromagnetism
9 replies · 3K views · last reply
PainterGuy
Hi,
Could you please help me with the queries below? Thank you.
Question 1:
Please have a look on this attachment. In the given attachment, the disk is mounted vertically and only a part of the disk passes thru the magnetic field at any instant. If entire surface of the disk was rotating in a uniform magnetic field then I don't think any eddy currents would be produced. Do you agree?
Question 2:
If the disk was instead mounted horizontally but still all of the disk rotating in a uniform magnetic field, would it result into production of any eddy currents?
Question 3:
It is said that an accelerating charge radiates electromagnetic waves, does this mean that the quantity of charge would reduce as a result of emanating electromagnetic waves?
Question 4:
Please have a look on this attachment. If the attachment is not clear please have a look here. I believe that "v" represents the direction of disk rotation. How is the direction of "v" is being determined? The direction of magnetic field is from left to right and disk is rotating clockwise when seen from the left side.
Question 5:
Diagram of a straight vertical wire carrying current I upward, with concentric blue circular magnetic field lines labelled B around it, and a right hand with thumb pointing up along the wire showing the right-hand rule.
We can see that there is circular magnetic field around wire but where are the north and south poles of this circular magnetic field?
Thanks a lot for your time and help.
  • Textbook figure 20.13 showing Faraday's disk dynamo: a copper disk between the poles of a permanent magnet, hand-cranked, wired through a resistor to an ammeter, with a lower inset showing v cross B force directions.
  • Diagram of a straight vertical wire carrying current I upward, with concentric blue circular magnetic field lines labeled B around it, and a right-hand thumb rule illustration showing the thumb along the current and fingers curling in the field direction.
  • Textbook page titled Eddy currents with two diagrams: figure 5a shows an aluminium disc spinning on a spindle, and figure 5b shows the disc passing between the poles of a horseshoe magnet.
Yes, but there will be a voltage between centre and rim of the disc.
Yes. Emf will be indued along the thickness of the disc.
No.
It is the instantaneous linear velocity of a point on the circular disc (with a direction tangential to the circle).
There cannot be a single isolated current carrying conductor, there's always at least one more conductor that acts as a return path for the current. Together they two form a single-turn coil which acts as a bar magnet and you can find its polarity.
It is not a dipole field so it doesn't have a well defined pole.
Thank you.
So, no eddy current but an emf will be induced. I was just trying to find some good picture to make my point clear and found out that it used to be called Faraday paradox back in the days. Please check this out: https://en.wikipedia.org/wiki/Homopolar_generator#Disk-type_generator
In the picture below I believe that the rim would have positive potential and the center negative potential. Please let me know if I'm wrong.
Diagram of a disk-type homopolar generator: a copper disk between a red-faced magnet labelled N above and a magnet labelled S below, with a wire from the rim and axle to a meter and an arrow marked clockwise on the disk.
So, you are saying that the eddy will be produced and an emf will be also induced. I had the construction below in mind.
Using right hand rule, it shows the direction of induced current at points A and B, and it looks like that lower and upper halves of the disk will have different charge distribution.
Diagram of a copper disk between an N pole magnet above and an S pole magnet below, with points A and B marked on the rim, a yellow highlight on the disk's left edge, and red arrows showing rotation direction.
cnh1995 said:
No.
So, it means that an an accelerating charge won't loose its charge. As radiating electromagnetic waves is energy therefore the charge must loose something, and I think it would be mass then.
@cnh1995 : Let's think of an infinite wire and in such a case we can ignore the return path.
@Dale: Yes, it does look like that it's not a dipole field but a magnet cannot exist as a uni-pole which also implies no magnetic field without a 'dipole' magnet.
Thank you for your time and help.
  • Diagram of a disk-type homopolar generator: a copper disk spins between a red-faced N magnet above and an S magnet below, with an arrow marked clockwise and wires leading to a meter.
  • Diagram of a copper disk spinning between a north pole magnet above and a south pole magnet below, with points A and B marked on the rim and red arrows showing the rotation direction.
Just because there are no magnetic monopoles does not imply that all magnetic fields are dipoles. There are many fields that are neither.
You have joined the center and the rim. I was talking about the same configuration, but not with the center and rim connected together like that, just the rotating disc.
In that case, current will flow from A to B on the upper surface and from B to A on the lower surface.
Diagram of a rotating copper disc between an N pole magnet above and an S pole magnet below, with points A and B marked on the rim, blue current paths drawn and red arrows showing rotation direction.
I am not sure if I can comment on this since I haven't studied EM radiation in depth, but just because radiating EM waves is radiating energy doesn't mean the charge has to lose something of its own (charge or mass). The charge is accelerated by means of some energy source and this radiation energy should ultimately come from that source.
Thank you.
If you say so, I'd agree with you. But could you please tell me of some fields which are neither monopole or dipole? I'm just curious.
Okay. But in the other configuration where the disc is horizontal, the center and rim were connected too so why is it different for this case when the disc is vertical as shown below?
Diagram of a vertical copper disc rotating between an N pole magnet above and an S pole magnet below, with brushes at points A and B on the rim and axle, red arrows showing rotation direction, and a yellow highlighted radial segment.
No problem then. But I believe that it should be mass because I did read somewhere in the past that electrically charged body is hard to accelerate compared to an equivalent neutral body, and we can use the relation mass=E/c^2.
Thanks a lot.
The field around a straight wire for one, and all of the multipole fields greater than dipole, and a plane wave.
Induced electric field in Faraday's law is not a dipole field.
That connection is necessary for a current to flow. Without that connection, there will only be voltage present between center and rim of the disc.
For the vertical disc in your diagram, no connection is required between center and rim as the current is flowing along the path I've shown in #6. If you connect the center and the rim, you are providing a parallel path for the current and some current will be diverted through that path.
I don't have enough knowledge about EM radiation and mass-energy equivalence. I can't comment on that.
