Space in plastic to fit a ball bearing?
The discussion focuses on designing a plastic piece to fit a ball bearing with an outer diameter of 10 mm. For achieving an interference fit, it is recommended to start with a hole diameter of 9 mm and incrementally increase by 0.5 mm until a snug fit is achieved. The importance of tolerances in drilling is emphasized, as well as the ease of enlarging a hole compared to reducing its size. The use of glue is suggested as a last resort for securing the ball bearing.
  • Understanding of fit types: interference fit and clearance fit
  • Knowledge of tolerances in mechanical design
  • Basic skills in plastic machining and drilling
  • Familiarity with ball bearing specifications
  • Research tolerance standards for plastic machining
  • Learn about different types of fits in mechanical design
  • Explore techniques for testing fit and adjustments in plastic parts
  • Investigate adhesive options for securing mechanical components
This discussion is beneficial for mechanical designers, engineers working with plastic components, and hobbyists involved in DIY projects requiring precise fitting of ball bearings.
Magnethos
I'm new in design and I'm designing a plastic piece where I want to fit a ball bearing.
The outer diameter of the ball bearing is 10 mm. If I want to fit it in the plastic. What measure I've to use in the plastic hole? 11 mm?
It all depends on the type of fit you are looking for, and the available tolerance for the drilling of the hole. If you are going for an interference fit, it's probably safe to assume that the plastic will be compliant enough for a less than 10mm hole (again, this all depends on the tolerance of the hole).
Also, remember that it's a lot easier to increase the diameter of a hole, than to try fixing a hole that is too wide. I'd start with a 9mm hole - test of fit - increase another 0.5mm - test for fit - and keep on with this until you have a snug interference fit.
And if all else fails, a little bit of glue is always allowable ;)
