Booster had to divert, but they already caught these before - there is a good chance the next flight will catch both, for the first flight to not discard any stage.
Looks like 2027 will become the year of fully reusable rockets.
Launch failure of Vulcan Centaur
This was their return to flight mission after they had solid rocket booster (SRB) issues in two of four flights. This time the SRBs worked without problem, but something went wrong later in the flight.
It is the first outright launch failure of ULA in 150-200 launches. An early mission reached an incorrect orbit but the payloads could compensate.
Edit: Rumors say it's likely a BE-4 engine that was underperforming. Vulcan has two of them in its core stage. A problem in a BE-4 blew up New Glenn earlier this year, Blue Origin found a fix that could be applied to existing engines. Vulcan made the first flight with these fixed engines. A problem with that modification which didn't show up in ground tests is plausible.
If this turns out to be true then New Glenn can't return to flight either until this new problem is understood and fixed.
