Spacecraft With Solar Mass Energy Equivalent Kinetic Energy
The discussion revolves around the gravitational effects of a spacecraft with kinetic energy equivalent to a solar mass as it passes through the solar system. Participants explore the implications of relativistic mass and gravitational interactions in the context of general relativity, debating whether the craft's effects would resemble those of a space shuttle or the sun.
  • Some participants question whether the gravitational effects of the spacecraft would be more similar to those of a space shuttle or the sun, suggesting that relativistic mass does not contribute to gravity in a straightforward manner.
  • Others argue that in the rest frame of the shuttle, it is at rest and should not exert significant gravitational influence on nearby planets.
  • A participant introduces the concept of gravito-magnetism, proposing that it could play a role in the gravitational interactions observed from the shuttle's frame.
  • There is a discussion about the stress-energy tensor as the source of gravity in general relativity, with some asserting that the momentum component of the spacecraft's energy would counterbalance its kinetic energy, leading to negligible gravitational effects.
  • Some participants reference a paper by Olson and Guarino, discussing the deflection angle of high-speed objects and how it differs from Newtonian predictions, though caution is expressed regarding the interpretation of its findings.
  • Disagreements arise over the validity of the proposed gravitational effects, with some asserting that neither of the original suggestions by the OP is correct and debating the degree of inaccuracy of each suggestion.
Participants do not reach a consensus on the gravitational effects of the spacecraft, with multiple competing views remaining. There is significant debate regarding the role of relativistic mass and gravito-magnetism, as well as the interpretation of relevant mathematical models.
Limitations include unresolved mathematical steps regarding the gravitational effects of the spacecraft and the dependence on definitions of relativistic mass and gravito-magnetism. The discussion also highlights the complexity of interpreting results from the cited paper.
Devin-M
Suppose in a different star system, a space shuttle sized spacecraft acquired a solar mass energy equivalent amount of kinetic energy, then passed through our solar system. While it was passing through the solar system would the craft’s gravitational effects be more similar to the space shuttle or to the sun?
Kinetic energy? So a Space Shuttle traveling at 0.99c?
Yes.
Space shuttle.
"Relativistic mass" is not a source of gravity in any naive sense. Look at it in the rest frame of the shuttle - it's at rest. Why would it expect to go around yanking planets out of orbit?
"Relativistic mass" is a concept best forgotten. It just confuses people.
Is a kumquat more like a saxophone or a pigeon?
It's not like either one.
The source of gravity in GR is not "mass" (relativistic or otherwise), it is the stress-energy tensor. It is true that in the solar system rest frame, the SET of the craft in your scenario would include a very large kinetic energy component; but it would also include a very large momentum component, and when you work out the math, it turns out that the momentum has the opposite effect from the kinetic energy, so they pretty much cancel. That means the intuitive answer that @Ibix gave--look at the source in its own rest frame--is pretty much correct. Certainly it is much closer to being correct than just looking at the total energy and ignoring everything else.
With its rest-mass, helped by extreme gravito-magnetism, perhaps?
Can I say that, moderators? Maybe Ibix can understand?
So, you are proposing that in the rest frame of the shuttle we can observe a planet (very blue shifted) orbiting its sun for millenia suddenly fly out of orbit when it gets near a small shuttle because of gravitomagnetism?
Or are you referring to the direction change of the shuttle relative to distant stars, from the perspective of the shuttle?
First one. In the frame of the shuttle there exists gravito-magnetism between the sun and the planet.
(Let us keep in mind that the speed of the solar system is ridiculously close to c in the frame of the shuttle)
(It's less weird in the frame of the planet)
And you think the shuttle will affect this?
I'd love to see some maths.
In the planet frame math is easy. Just a super energetic particle (shuttle) passes the planet.
You haven't shown that it yanks the planet out of its orbit. Peter already stated why the effect of the passage of the shuttle is negligible.
Expanding on this a bit... Suppose you're inside the shuttle, looking out the window at the planets zipping past you at 0.99c. Everything inside the shuttle is normal. Why would you expect the planets' paths to be deflected?
No. You are cluttering the thread with uninformed and wrong speculation.
As such, since you explicitly asked for moderator feedback, you have now been banned from further posting in this thread.
If the math is so easy, go do it. And find out what the answer is, instead of waving your hands and cluttering the thread.
@pervect usually cites Olson and Guarino. I think only the abstract is available, but the conclusion stated there is that the deflection angle of a high speed object is higher by a factor of ##1+\beta^2## than a Newtonian analysis, where ##\beta=v/c## is the speed of the shuttle.
The abstract of that paper, though, shows a factor of ##\gamma## in what they call the "active gravitational mass", i.e., taken at face value, they seem to be saying that the relativistic mass is the source of gravit, with an extra GR factor of ##1 + \beta^2## that comes in for similar reasons as in the analysis of light bending by the Sun.
However, they are defining "active gravitational mass" in a very narrow way: it is "measured by the transverse (and longitudinal) velocities which such a moving mass induces in test particles initially at rest near its path". That is not the same as the kind of "gravitational effects" that the OP is asking about.
I have so far been unable to find a non-paywalled version of the Olson & Guarino paper (for example, a preprint does not appear to be on arxiv.org), so I can't comment on the details of their reasoning. But I would be cautious about interpreting it with regard to this discussion.
It has been a long time since I did this, but I believe the factor of ~2 is right. It's the same as the factor of 2 in the deflection of light.
Note that neither of the two suggestions of the OP is correct.
As far as "gravitomagnetism", while there is an effect that can be called that, I can think of exactly zero cases where this is the best way to solve problems in GR. There may be one or two where it's simpler by accident, but it's probably at least as much work to verify that the answer is right as to do it correctly in the first place. It's fairly useless.
I agree that neither one is exactly correct, but the question is which (if either) one is reasonably close to being correct.
But neither is reasonably close. One is off by a factor of 2 and the other by a factor of a zillion.
You can say 2 is closer, but that's like saying the American Revolution happened last week is more correct than saying it happened yesterday. In some sense it is, but still...
  • Haha
No, it's like saying that the American Revolution happened two centuries ago is more correct than saying it happened yesterday. Yes, neither is exactly correct, but one is indeed a lot closer than the other. Just like a factor of 2 is a lot closer than a factor of a zillion.
Let's improve the analogy - Did the American revolution happen yesterday or in 1900 (factor of 2). If someone were to ask which is right, shouldn't we say neither?
If you present two wrong alternatives, making one more wrong does not make the other more right.
I would say that which is "right" is not the important question. The important question is, which, if either, of these is close enough?
In the case of your analogy, I would agree that neither is close enough, because historically speaking, yesterday is not much more different from the 1770s and 1780s than 1900 was. They're both very different from the time of the American Revolution, and there are many significant historical events in between in both cases, so neither one is close enough. (Note that by this criterion, even saying that the American Revolution happened in the 1790s is not close enough, since the Constitution, a significant historical event, was in between then and the revolution. So I should indeed retract my earlier statement that "two centuries" would be reasonably close. You would need to say two and a half centuries.)
In the case of the OP's question, however, being only a factor of 2 off from the correct answer might well be close enough for many purposes. Sure, you'll be somewhat off when predicting the exact perturbations on test objects in the path of the flyby. But you will correctly predict that no significant disruption of the solar system as a whole will occur.
Whereas being off by a factor of a zillion won't be anywhere near close enough for anything. There you're expecting the solar system to be seriously disrupted, when nothing like that will actually occur.
Indeed. I think I need new glasses.
The obvious problem with the application of their reasoning here is that they are likely using the Schwarzschild metric, which implies that the shuttle must be a test particle with zero active mass. Thus the planet can't react at all.
We could try considering it as an elastic collision. The Earth has rest mass ##M## and initial and final Lorentz gamma factors ##1## and ##\Gamma'##, and the shuttle has mass ##m## and initial and final gammas ##\gamma## and ##\gamma'##. Conservation of the zeroth component of four momentum is ##M+\gamma m=\Gamma' M+\gamma'm##, which becomes ##\Gamma'=1+\frac mM(\gamma-\gamma')##. To escape from the solar system the Earth needs a gamma factor of about ##1+10^{-9}## and given a mass ratio between the shuttle and Earth of about ##10^{-20}## that means the shuttle has to decrease its gamma factor by about ##10^{11}## in the interaction.
I don't immediately see how that could happen.
Is the Aichelburg/Sexl solution relevant here?
I believe that's how a test particle describes the Schwarzschild metric of the near-##c## Earth, but I think that again implicitly assumes no gravitational effect of the test particle on the Earth.
Ah - right.
I don't see how they could be since they are explicitly giving a nonzero active gravitational mass to the object (the shuttle in this scenario). That's why I want to look at the details of their paper: I want to see how they are actually modeling things mathematically.
  • · Replies 53 ·
  • · Replies 125 ·
  • · Replies 64 ·
12K
  • · Replies 21 ·
