Spacetime distance between spacelike related events
41 replies · 5K views
cianfa72
TL;DR
How to define the spacetime 'distance' between events belonging to a spacelike hypersurface
Hi,
in general relativity I'm aware of the spacetime 'distance' between two timelike related events is maximized by the free falling timelike path (zero proper acceleration) joining them.
Consider now a couple of events belonging to a spacelike hypersurface (AFAIK it is an hypersurface with the feature that all the 'directions' belonging to it are actually spacelike in the tangent space at each point).
How is defined in this case the maximum (or minimum ?) spacetime 'distance' between a couple of events belonging to it ?
Thanks in advance !
on Phys.org
[tex]ds^2=c^2dt^2-dx^2-dy^2-dz^2= -dl_0^2 <0[/tex]
where ##dl_0## is (infinitesimal) minimum or proper length measured in the IFR where the two events take place simultaneous ##dt=0##.
Just to be clear: we are talking about GR with events A and B not infinitesimally separated.
I assumed the following definition: two events are said spacelike separated if there exist no timelike or null path joining them.
You can define spacelike geodesics, if that's what you're asking. As far as I'm aware you use the geodesic equation and simply impose the condition that ##g_{\mu\nu}\frac{dx^\mu}{d\lambda}\frac{dx^\nu}{d\lambda}## have the appropriate sign for your metric signature.
@cianfa is asking about the extremal spacelike curve that lies in a given spacelike hypersurface containing the two events. That’s not the same thing as the spacelike geodesic between the two events (although it may be more useful if the hypersurface was chosen to correspond to some interesting/relevant simultaneity convention).
Why not take the hypersurface with its induced metric and coordinates and simply extremize the distance between two points lying on it?
cianfa72 said:
Summary:: How to define the spacetime 'distance' between events belonging to a spacelike hypersurface
By doing what I said, you will find that the curve is a spacelike geodesic. However it may not be a geodesic in the full space (i.e., spacetime).
Just a comment:
one probably needs to be specific about restrictions or conditions.
Here are two events on a spacelike surface that are timelike-related.
You can exclude events on this spacelike surface that causally-related to the lower-event A
by drawing the boundary and interior of the light-cone of A and excluding events in the intersection.
robphy said:
Just a comment:
I assumed the OP meant a geodesic within the hypersurface, with induced metric (though they didn't necessarily know the terminology or techniques). In that case, there is nothing to exclude - there is a spacelike spiral geodesic of the induced metric between your two points.
[strike]Yes, there is a geodesic on the spacelike surface I gave.[/strike]
hmmm... I’m not so sure now.
But, I raised the issue because
the title says
but the summary in the original post says
and later the original poster says
So, my post is to suggest that the question should be clarified
since two events on a spacelike surface are not necessarily spacelike-related.
Yes, this is something a lot of people don't stop to think about when they think about spacelike surfaces.
The technically correct term for a surface such that any two points of the surface are spacelike separated from each other is, IIRC, "acausal".
That was my original question based on an incorrect assumption (see below).
Ah that was my incorrect understanding !
ok good point, I was not aware about this definition.
Does this definition make sense for a couple of spacelike separated events ?
What about instead the following definition of spacelike hypersurface: a 3-dimensional hypersurface such that at each point (event) the normal vector (in the attached tangent space of course) is timelike ?
That's the usual definition of a spacelike hypersurface, i.e., a 3D hypersurface such that the normal vector is timelike everywhere. You can then take such a spacelike hyersurface as a surface of simultaneity and then define the spatial distances for points on the hypersurface by the length of geodesics conneting the point in the induced spatial metric. This is of course not always possible for any two points but usually only locally. In general you can even synchronize clocks of a set of observers along a spacelike curve only locally. If you have a closed spacelike curve usually you cannot synchronize the clocks of these observers.
One famous example is the rotating disk in Minkowski spacetime. This was discussed also recently in this forum at length.
A nice discussion about this problem is in Landau and Lifshitz vol. II.
vanhees71 said:
You can then take such a spacelike hyersurface as a surface of simultaneity and then define the spatial distances for points on the hypersurface by the length of geodesics connecting the point in the induced spatial metric. This is of course not always possible for any two points but usually only locally
Why not ? Assuming a connected manifold all the curves (geodesics or not) that lie in the given spacelike hypersurface are themselves spacelike, thus why can't we find out an extremal spacelike curve joining the two given events belonging to the hypersurface ?
Your definition of "spacelike separated events" is fine.
The helical spacelike surface @robphy described satisfies this definition.
vanhees71 said:
if you already have a spacelike hypersurface, there's no problem since this defines a hypersurface of simultaneity
No, it doesn't. The helical spacelike surface that @robphy described is a counterexample. A hypersurface of simultaneity must be acausal, which is a much stronger condition than just being a spacelike hypersurface.
By the way I believe that any spacelike hypersurface equipped with the induced metric from the pseudo-riemman spacetime metric is actually positive definite.
Yes, this is true without exception.
My impression was and is that it sufficient (and necessary) to specify a closed space-like hypersurface to do what the OP wants.
If the surface isn't closed, the difficulties alluded to arise. This is not a frivolous point, because the rotating disk is a physical example that can generate non-closed surfaces. The issue of closed vs non-closed surfaces can arise even in small regions.
The methodology, once one has a closed surface, is, as others have mentioned, to use a projection operator to induce a 3-metric on the surface from the 4-metric of the space-time. Once one has the induced 3-metric, one has at least a local notion of distance. Usually textbooks stop with having defined a metric, and don't go on to discuss how one gets distance from a metric over extended regions.
I tend to think of distance over an extended region of a space with a metric as the length of the shortest geodesic connecting them. Though as I said, this isn't from a textbook.
However, this is all from memory, I don't have a reference handy that formally defines a closed space-like hypersurface, for instance.
I'm not even sure what informal definition you are using. Can you elaborate? Or give some specific examples of closed spacelike 3-surfaces?
I don’t think Minkowski spacetime admits any closed spacelike 3- surfaces.
The requirement I’ve seen for a foliation is acausal, as mentioned by others in this thread.
If "closed" means "manifold without boundary", yes, I believe that's correct. The only fairly well known spacetime I'm aware of that admits closed spacelike 3-surfaces in this sense is spatially closed FRW spacetime.
Which is the problem with this kind of hypersurface ? We have a spacelike 3D hypersurface with an (induced) metric that's positive definite on it.
The issue you are referring to has something to do with the 'geodesic completeness' --- see Hopf–Rinow theorem ?
A trivial example that is flat but not topologically trivial is the flat 3-torus X R, with Minkowski metric everywhere. But, of course, this is not what is normally meant by Minkowski space.
Any though about this?
There might not be one. See below.
Yes. But, as has been pointed out, not all hypersurfaces that meet this condition also meet the much more stringent condition, the "acausal" condition, that every pair of events in them are spacelike separated. Whether that is a "problem" or not depends on what you are trying to do with the hypersurface.
robphy said:
@cianfa72
Given the discussion so far, with some caveats raised, can you more precisely reformulate your question?
Given a spacelike hypersurface with no stronger "acasual" condition, does always exist a spacelike geodesic that lives on it joining two given events belonging to that hypersurface ?
