SpaceX: First stage landed Satellites in orbit
The discussion centers around the recent successful launch and landing of the SpaceX Falcon 9 first stage, which delivered 11 OrbComm satellites to Earth orbit. Participants explore the implications of this achievement for spaceflight, the engineering behind the rocket's recovery, and comparisons with other launch systems.
  • Some participants express excitement over the successful launch and landing, viewing it as a historic achievement in spaceflight.
  • Others clarify that the first stage did not reach orbit but was designed to accelerate the second stage to a sufficient velocity for orbital insertion.
  • Concerns are raised about the reusability of the first stage, with some suggesting that refurbishing costs may negate the benefits of recovery.
  • Participants discuss the engineering challenges and risks associated with landing on land versus a barge, noting the advantages of a larger landing platform.
  • There are differing opinions on the significance of the Falcon 9's achievement compared to other suborbital flights, particularly in relation to Blue Origin's missions.
  • Some participants question the decision to abandon the barge for landing and speculate on the reasons behind this choice.
  • Technical details are shared regarding the launch profile, stage separation speeds, and the mechanics of the landing process.
  • Comparisons are made between the Falcon 9 recovery system and the Space Shuttle's Solid Rocket Boosters (SRBs), discussing benefits and downsides of each approach.
Participants generally agree on the significance of the launch and landing but express differing views on the implications for reusability, comparisons with other space missions, and the engineering decisions made by SpaceX. The discussion remains unresolved on several points, particularly regarding the future use of the recovered first stage and the broader impact of these developments on the space industry.
Some participants note the need for further clarification on the technical aspects of the landing process and the implications of reusability, indicating that assumptions about costs and engineering challenges are still open for discussion.
  • #122
Curious. Rate of descent appears in the same ballpark as the successful Cape landing. Possible differences: A sea induced pitch angle on the barge increasing the load on the down slope leg? Worse, a barge pitch up *rate* under the down side leg? More residual fuel mass than at the Cape? Clearly there was some.
  • #123
Nope, leg failed to lock in place. Landing was fine.
  • #124
Yes I know it was the leg, but I thought the leg failed due to some kind of overstress, brought on by the landing?
  • #125
Media reports, "The company initially said it touched down harder than planned amid 10 to 15 ft swells. Later, ... Mr Musk suggested the mishap appeared to be the result of a simple mechanical failure...indicating 'touchdown speed was OK,' but the lock down mechanism on one leg didn't latch 'so it tipped over after landing'"
  • #126
That agrees with what I saw - the touchdown velocity was sufficiently slow, so there wasn't an overstress, the leg just never locked in place, so it was free to fold and tip over after landing.
  • #127
Why should the rocket explode after tipping over ? does that mean there was a lot of fuel left ?
  • #128
There was some fuel left, and there was also some helium pressurant left, so the tanks were pressurized. When the tanks ruptured (from falling over), the pressure sprayed the fuel and oxidizer around, and some of the fuel ignited on the still smoldering engines.
  • #129
One leg simply failed to lock in place?
It sounds like a really basic design flaw which ought to be easily solvable, but a surprising explanation.
I know that there are occasional similar incidents with aircraft landing gear locking, which I imagine must work on a similar mechanical principle, but that's about once in 10,000 landings.
  • #130
Yes it's very apparent over a second or so, the tanks rupture and escaping fuel oxidizer immediately condense air moisture forming white clouds; when the clouds hit that hot aft engine kaboom.
  • #131
Aircrafts don't go to space (well, with irrelevant exceptions), and much more money goes into their development. Somewhere I read that ice was related to the issue.
  • #132
Iron Man: How'd you solve the icing problem?
Iron Monger: Icing problem?
[his suit begins to fail]
Iron Man: Might want to look into it.
[He raps his fist on Iron Monger's frozen helmet as his suit fails and plummets to the ground]
  • · Replies 30 ·
11K
  • · Replies 43 ·
  • · Replies 271 ·
32K
  • · Replies 24 ·
  • · Replies 19 ·
