How to Calculate Spacing for Bridge Expansion with Linear Expansion Coefficient
  • Thread starter Thread starter DrMcDreamy
To calculate the spacing needed for bridge expansion due to temperature increase, the formula ΔL = L₀αΔT is used, where L₀ is the original length, α is the linear expansion coefficient, and ΔT is the change in temperature. For a bridge segment of 76 m and a linear expansion coefficient of 1.2 × 10−5(°C)−1, an increase of 69°F (approximately 20.5°C) results in a calculated expansion of 0.0348 m. The final answer, converted to centimeters, is 3.48 cm. The initial confusion arose from not recognizing the required units for the answer. Proper unit conversion is crucial in such calculations.
DrMcDreamy
A bridge is made with segments of concrete 76 m long (at the original temperature). If the linear expansion coefficient is 1.2 × 10−5(◦C)−1, how much spacing is needed to allow for expansion for an increase in temperature of 69◦F? Answer in units of cm.
I don't know, we never did this in lecture, so I lost as to what to do.
What formula am I supposed to use?
For a formula check
http://hyperphysics.phy-astr.gsu.edu/hbase/thermo/thexp.html
Thank you!
So it would be:
\DeltaL=Lo\alpha\DeltaT
\DeltaL= (76 m)(1.2 x 10-5)(◦C)-1(20.5◦C+17.7◦C)
\DeltaL=0.0348 m
^It came out to be wrong, so what did I do wrong?
ΔL=0.0348 m
That's what's wrong.
Oh $h*t! 3.48 cm crap I didnt even realize it had asked in cm!
10K
