Charlie Cheap
- 76
- 16
- TL;DR
- How much is actually gained?
Having made/modified my own distributors for years, I was surprised to see MSD (Multiple Spark Discharge) company show their graph using Points, HEI, and Performance HEI comparisons, with little difference in Horse Power made, up to about 6000 RPM. I know a points mechanical system makes a longer spark but runs out of TIME to build spark at higher RPM. Multiple sparks can simulate the longer points spark but is not the same...but better than a very hot short ONE. Between 3000 - 6000 RPM the points and performance HEI traded the lead back and forth making more HP at different RPM's. The HEI might make more power at 5000 RPM but the points may make more at 5500. My thinking is, as the mixture swirls around the chamber, the longer spark, though not as hot as the HEI, still manages to see and ignite the mixture, while the HEI sparks in a vacant area. I am building a 2.3 Ford 4-cylinder out of an 85 Mustang, and to avoid any computer, I am using points. The 4-cylinder has lots of time to build primary voltage with only 4 lobes on the points cam. Just one reason for points. Using Borg Warner Division (BWD) parts, which use the best available materials for points/condenser/rotor/cap, and a Hot ACCEL coil with 1.2 ohms primary, 100 to 1 windings, a 1 ohm Ignition resistor, copper plug wires, and Platinum resistance sparkplugs, I think I will have plenty of spark to fire my 2-barrel carburetor fueled engine. Anyone have improvements or modifications I should make? I have nothing against computers and I am using one to type this, I just like simple if it works. For my purpose I see little if any gain to add a module (computer), O2 sensor, and probably more sensors if I go to Fuel Injection.
